- Thank you received: 8
Duesenberg Steering
- pfree3233
26 Jul 2023 22:31 #47456
by pfree3233
Replied by pfree3233 on topic Duesenberg Steering
Hi, can't be much to a 71 Dodge p/u chassis. Doesn't matter what body is on top, check bushings, ball joints, tie rod ends, etc. Good luck
Pat
Pat
- Jay
25 Jul 2023 15:09 #47454
by Jay
If it burns fuel and makes noise I want to see it.
Replied by Jay on topic Duesenberg Steering
I'm sorry, you see, as a Replicar this Dusy is built on a Dodge Truck chassis. 1971.
I've been reviewing the Sweptline Forums looking for clues. Tis a Puzzlement.
25 Jul 2023 11:43 #47453
by pete kelly
Replied by pete kelly on topic Duesenberg Steering
I am serious; that worked for Bob McEwan on his Cord coupe.
- Jay
25 Jul 2023 00:41 #47452
by Jay
Would that be attached to the Reciprocating Dingle Arm in the Turbo Encabulator?
24 Jul 2023 22:08 #47450
by pete kelly
If all else fails replace the RR spring!
- Jay
24 Jul 2023 18:18 #47449
by Jay
Well, we increased the caster. Rebuilt the Power Steering Control Valve. Now we've started rebushing all points and have ordered new tires, these are a bit old. Sounds like we're on the same page.
Thanks Mike.
Thanks Mike.
23 Jul 2023 04:35 #47443
Replied by mikespeed35 on topic Duesenberg Steering
Check all front end measurements. If that doesn't work shim the front axle, if it has a axle. Start with 3 degrees. Shims available at Summit Racing.
- Jay
21 Jul 2023 19:32 #47439
by Jay
Duesenberg Steering was created by Jay
Have a 1971 Duesenberg II built on a Dodge Pick up chassis. Steering develops a terrible shimmy after hitting a bump. Death wobble, violent shaking, have to come to a complete stop.
Anybody else have this problem? What did you do?
Thank You.
Thank You.
