1932 auburn 8-100 spindle assembly help
- Ivor
23 Aug 2022 07:37 #45883
by Ivor
Replied by Ivor on topic 1932 auburn 8-100 spindle assembly help
- danc2003
18 Aug 2022 01:48 #45875
by danc2003
1932 auburn 8-100 spindle assembly help was created by danc2003
Hello I’m installing new king pins, bearing and bushings in my 8-100 auburn. They old ones I took out are on the bottom and had a ford part number on the bearing and no shims installed. The spindle if car jacked up would move up and down maybe 1/8”. Upon installing the new one should spindle have no play in it between bearing and axle. Also if shims are required where do they install. Any help is appreciated thanks.
