Columbia Single Speed Axles...
- Gerczak
- Forum Member
04 Nov 2023 02:27 #47927
by Gerczak
Replied by Gerczak on topic Columbia Single Speed Axles...
- Tim Gilmartin
- Thank you received: 57
03 Nov 2023 14:25 #47925
by Tim Gilmartin
Replied by Tim Gilmartin on topic Columbia Single Speed Axles...
- Justin Kerns
- Thank you received: 13
03 Nov 2023 02:52 #47923
by Justin Kerns
Justin
1932 Auburn 12-160A Sedan
1933 Auburn 12-161A Sedan
Replied by Justin Kerns on topic Columbia Single Speed Axles...
Justin
- Gerczak
- Forum Member
01 Nov 2023 04:05 #47911
by Gerczak
Columbia Single Speed Axles... was created by Gerczak
All,
I have been doing some research and it has pointed me to the Auburn experts because it is my understanding that Auburn purchased Columbia Axle back in the day. I am working on a 1928 Kissel Car that has a full Columbia Axle that has 51/10 axle (5.1 ratio). I am in the process of rebuilding it and I noticed a few issues, specifically the ring gear. I know Auburn used 2-speed Columbias but did they also use single speed Columbia Axles? Was the 51 tooth ring gear common and are they available? Did they make a single speed diff with a better ratio? Any available? Is there anything else that will fit it?
I intend to use the axle housing because I want to use the wheels/brakes/etc. I plan to have a new driveshaft made so if the diff is shorter or longer would not be a problem. I appreciate any information/leads in advance.
