8-100 GU series Valve Adj.
- Mike Dube
Topic Author
11 Aug 2003 00:27 #614
by Mike Dube
8-100A
Replied by Mike Dube on topic 8-100 GU series Valve Adj.
8-100A
- Lycoming-8
10 Aug 2003 04:57 #610
by Lycoming-8
'31 Auburn Coupe
Replied by Lycoming-8 on topic 8-100 GU series Valve Adj.
'31 Auburn Coupe
The following user(s) said Thank You: DONALD.ELMER
- Mike Dube
Topic Author
- Auburn/Cord Parts
28 Jul 2003 22:56 #557
by Auburn/Cord Parts
Replied by Auburn/Cord Parts on topic Re: 8-100 GU series valve adj.
- Lycoming-8
28 Jul 2003 17:57 #550
by Lycoming-8
'31 Auburn Coupe
'31 Auburn Coupe
- Mike Dube
Topic Author
26 Jul 2003 19:57 #533
by Mike Dube
8-100A
8-100 GU series Valve Adj. was created by Mike Dube
What should I use as clearance to adjust my valves "cold" ? The numbers are .006 intake /.008 exhaust hot. I'd prefer not to do it hot, for obvious reasons. I just adjusted them all to .010, and they sound much too loose. Maybe .008 intake and .010 exhaust?
Thanks guys,
Thanks guys,
8-100A
