Fuel tank sending unit repair
- red.auburn851
Marcus Shelley
I used solid core silver solder, (only a small percentage of silver). Same stuff that I use for sweating copper plumbing.
Andreas: That King Sealy is good tubing, but the red fluid turns clear after awhile. Curt Schulze has the good stuff.
- 61xlch
- oldbanger71
Why didn't you just block the forth pipe instead of removing ?
this way you would be able to reopen the pipe if needed.
@ Mark : why didn't you unsolder the pipe instead of cutting off ? With what kind of solder did you solder the new pipe on ?
812 310 121 S
- Steve Miller
- sds1861
I was just reviewing your photos and noticed a 4th copper line coming out of your gas tank unit. I see the line for the gauge, the fuel supply, and the vent, but what does that 4th line connect to?
Regards,
Steve Stevens
Actually, that looks like nothing that some copper tubing, a brake-line bending tool (to prevent kinks), a jig, and some soldering couldn't solve. You might try a local radiator shop, since the soldering skills are right up their alley.
[i:36fc6unb]"There are Three Rules for soldering: the item must be clean, it must be clean, and it must be clean. Do that and you can solder ice cubes to Teflon."[/i:36fc6unb] --My Old Man.
- Steve Miller
Thanks I'll see if I can track them downCurt Schulze wrote: The tank unit is 1/2 of the telegage system. They repair those units.
- Steve Miller
- sds1861
- Steve Miller
I agree that posting pictures is a PITA
- Steve Miller
