Gas tank clean out
- oldbanger71
It will remain elastic so it will not brake at joints if rivet together. we have used it to seal aircrafttanks with a lot of mouvement in joints because of airpressure and thermal differences with very good sucsess.
812 310 121 S
- Brad J.
- 1930 Jordan
1930 Jordan"G" line 90,1953 Plymouth,1951 Chrysler Saratoga,1975 Dart,1974 Schwinn Collgate,1978 Schwinn Continental,1971 Honda 500"4",1973 Honda 350"twin",1975 Honda 500"twin",1955 Norton,1988 Honda Shadow custom,05 crossfire roadster.
- Steve Miller
Thanks again everybody
P.S. 1930 Jordan if you do find the name of that product I would really appreciate it if you could let me know, sounds like the ticket for me as the outside of my tank is in great shape, it even had some cloth strips between the tank and the straps which I think may be original (at least they looked like it) which is another reason I don't want to take it and have the outside stripped
- 1930 Jordan
- John Alkire
You have a couple of options, as some of the guys have pointed out. The last tank I did had 1/2 to 3/4" of hard scale/crud in the bottom. The car had been sitting for over 50 years.
We started with Red Devil Lye (note not Draino). We added a couple of bottles to the tank along with warm water. The solution heats up considerabley more as the lye (sodium hydroxide) goes into solution. We did this a couple of times, the dried it out. It got a lot of stuff out. By the way, Muriatic acid (hydrochloric acid) will not do anything to old gas gunk that is hydrocarbon based. HCl is mainly good for getting rid of surface rust, but be careful as it will attack the steel as well. Not good for an old, thin, corroded gas tank.
You need to handle the stuff very carefully - rubber chemical gloves, long sleeves, face and eye protection, etc. You don't want it in your eyes.
After we got a good bit of the scale out, we did like others are suggesting - we tied it to an engine stand and tossed in several feet of chain and gave it a spin now and then. After as while, we got nearly everything out.
The last step was to internally coat the tank with Bill Hirsch's gas tank sealer - get the alcohol resistant one and follow the directions. I have used his sealers for over 20 years and always had good luck with them.
Hope this helps.
BTW - we happen to have a shop near Houston that will cut open the end of the tank, sand blast the inside, and reweld it back together. A lot easier than doing it yourself and you get a squeeky clean tank that can then be coated. You might want to check around to see if there are any shops like this in your area.
John Alkire
Houston, TX
ACD Life Member
I like the cement mixer idea!
- Steve Miller
Thanks again
- Steve Miller
