Bijur lubricator or grease fittings?
- Rum-Runner
23 Mar 2010 23:50 #16166
by Rum-Runner
Replied by Rum-Runner on topic Bijur lubricator or grease fittings?
I do the same as Mike, it works very well, I've been using marine grease.
- Neal Ziff
23 Mar 2010 14:26 #16163
by Neal Ziff
Neal
_________________
1930 8-95 Cabriolet
Replied by Neal Ziff on topic Bijur lubricator or grease fittings?
thanks Mike - I'm going to give that a try
Neal
_________________
1930 8-95 Cabriolet
- Thank you received: 195
23 Mar 2010 04:23 #16159
Replied by mikespeed35 on topic Bijur lubricator or grease fittings?
L-29 Cords used a grease cup to lub the water pump in latter models so grease should work fine. You should use water pump grease though.
- Neal Ziff
23 Mar 2010 03:17 #16157
by Neal Ziff
Neal
_________________
1930 8-95 Cabriolet
The bijur also lubricates the water pump on the end of the generator. Do you think greasing this will also work just as well?
Neal
_________________
1930 8-95 Cabriolet
- Rum-Runner
23 Mar 2010 01:30 #16155
by Rum-Runner
Replied by Rum-Runner on topic Carburetor
Andreas,
My guess is you have a Schebler updraft carburetor. The intake points towards the rear of the car. The air cleaner that is used is a simple round screen filter and the biggest problem you will have is to find the adapter fitting that goes from the carburetor inlet to the filter. The steering column is really close to the carburetor. The adapter slips into the carburetor, and comes up at an angle to clear the steering, with the air cleaner installed into the adapter. Fortunately for me, I have one on the Rum-Runner. However,I've noticed only a very few of these over the years. I seem to remember hearing someone say that this had either been an option offered by Auburn, or an aftermarket item. Regards, Bob Esten & The Rum-Runner
- 61xlch
22 Mar 2010 20:19 #16152
by 61xlch
Replied by 61xlch on topic Bijur lubricator or grease fittings?
Thanks for all your input. I am not that purest about the Bijur, I will use grease fittings and remove the lines.
(BTW: Did anybody try to install a kind of central grease gun instead of the oiling pump? But probably no good idea , because the grease will not pass all fittings in the same amount.)
Regarding the the 2-speed: Yes - its not original, but its in my car. And I will not have to be judged with this car in Germany. I like to have everything in working order, regardless if its original or not.
My intention is possibly use in mountains, therefore shifting the 2-speed could be helpful, isnt it?
Well, keep in mind, in Germany we do not have these endless highways without much traffic like in the Great Plaines, though we have to shift pretty often <!-- s;-) --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s;-) -->
I dont care too much about correct speedometer reading. What I am looking for is the vacuum control valve unit.
Further on I am missing an air filter at my carburator intake. Any ideas?
Thanks again,
Andreas
Thanks again,
Andreas
22 Mar 2010 02:56 #16146
I use my Bijur with 50 wt. oil.
- Mike Dube
22 Mar 2010 01:04 #16144
by Mike Dube
8-100A
Replied by Mike Dube on topic Bijur lubricator or grease fittings?
Andreas,
My Bijur jar contains a greenish 2 stroke motor oil, that I am told is close in color to the original Bijur Fluid. It is not working because, as Bill said, it makes a big mess. I remove the Bijur fittings one or two times a year, thread in a zerk & apply grease, then put the Bijur fittings back in. The car hasn't been judged in many years so I don't know why I still bother, but I do.
As to all the controls you will need to hook up your two speed, keep in mind that since 1931's never had a 2 speed, if you were to have it judged by ACD judges, it would cost you. While it could be done if you could find all the pieces, I really think most people with '31 cars and a dual ratio make an accomodation for the speedometer and don't shift the rear axle.
What is behind the dash is basically a gearbox on the back of the speedometer that changes it's ratio and a rod that goes through the firewall and operates the various vacuum valves that shift the rear end.
Wish you good luck however you decide to go.
8-100A
- Rum-Runner
22 Mar 2010 00:58 #16143
by Rum-Runner
Andreas; We've been touring with the Rum-Runner for over 10 years, the Bijur lines are permanently unhooked with regular grease fittings in place. The Bijur system will provide lots of lubrication underneath the car, to the garage floor, and also parts of the car not requiring it. If you want to be a purest about this, hook everything up and every so often, remove the lines, screw in a grease fitting and give the car a grease job and reattach the lines.
I'm a little confused about the 2-speed, I thought the 8-98 was not available with a 2-speed rear end, perhaps someone can enlighten me on this. Regards, Bob Esten & The Rum-Runner
22 Mar 2010 00:06 #16140
by
Replied by on topic Bijur lubricator or grease fittings?
How much do you value your garage floor? Most of the Duesenberg owners don't put oil in the bijur resevoirs because of the nasty drippage that develops. I'd go with zerks. or for more period accuracy, alemite fittings.
- 61xlch
21 Mar 2010 21:53 #16138
by 61xlch
Bijur lubricator or grease fittings? was created by 61xlch
Dear Auburn friends,
I am missing the bijur lubricator at my 8-98.
Does anybody has a lubricator for sale?
Is there any problem with installing grease fittings/ nipples instaed the lubricator?
Further on I am still looking for all the shifting hardware for my 2-speed rearend, especially the control unit in the dashboard.
Andreas
Andreas
