question about details of 8-98
- 61xlch
you got PM.
BTW: posting pics in forums is very easy with special picture services. I use www.picr.de (its German, but you will find similar free services in English too).
I only have to choose the pics, mark and copy them und and one click later its in the thread, always in perfect size.
Regards,
Andreas
- Steve Miller
- Rum-Runner
Bob
- Rum-Runner
The door panels are held on with a bent metal spring loaded clip which hooks into the door panel and pushes into the holes in the metal located around the door perimeter. I am hoping all my pictures post properly and you will notice that at the bottom corners are one screw with a trim washer in each corner. The Rum-Runner is an 8-98A, the tops of the door panel are held on by the trim and perhaps something else which may be hidden behind the trim. If you need any more info please ask and I'll try to answer your question or post pictures if possible. Regards, Bob Esten and the Rum-Runner.
- 61xlch
There is no VIN-tag on the floor. I only found 4-digit number on the RH frame rail.
And a Motor-No. (GU
) on the engine tag LH side.
This engine number (GU
) is the VIN in the title! Is this a mistake? I am a bit confused about.
Regards,
Andreas
CORDially Mik
- 61xlch
Finish Nails I dont know, anybody has a link or a pic of them?
At my A-posts are some old nail pins to be seen in the wood under the inner side panel, but they do not really fix the panels. I can push the panels on these nails but it falls apart again..., because these nails doesnt have any heads, its more like needles... <!-- s:? --><img src="{SMILIES_PATH}/icon_confused.gif" alt="" title="Confused" /><!-- s:? -->
Its my first Pre War Project, I am more familiar with 50ies or later cars...
Regards
Andreas
My 2 Cents
K Clark
- oldbanger71
If you are unsure, ask one of the Auburn Judge of the ACD-Club how it should be, or place this question in the restoration guide section.
Philipp
812 310 121 S
- 61xlch
Sorry, you got me wrong. My door panels were fixed only by the nails at bottom and top, which I already removed. My question is how I can fix the panels now in the original way.
I could use any plastic mounting hardware from newer cars or visible screws or other stuff, but I would like to do it in the original way.
Andreas
- oldbanger71
Usualy the sidetrimm in most cars are fitted witch sort of clips fitted to the trimpanel and are pushed into the driled holes in the inner doorskin. in your case you will have to detach the top and bottom nails anyway, so you can do that and then your able to feel or see where the clips are. then you need two flat and long pieces of either steel, or brass - no alu as itts not strong enough, place the flat pieces above and ounderneath each clip between trimpanel and dorrinnerskin and leaver them out ( one at the time and start at the bottom ). be careful since you don't know what's behind the panel and don't know what the trimpanel is made of. it can be cardboard or thin wood.
It's possible that not very much is holding YOUR timpanel other than the visible.
Good luck and happy easter <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
812 310 121 S
- 61xlch
Most questions cleared up, my remaining question is the right attachment of the inner door panels. On most cars I cant see any screws or retainers. I dont like drilling holes and using visible screws if this is not original.
Regards,
Andreas
- Lance
Good luck
Lance....8 98A
- tresenreiter
about the inner door panels I can't give you the correct answer,
but the inner screw for the doorhandle is the same like that on
my 1931 Auburn 8-98A. My Dashboard looks like yours.
Greetings from Hamburg.
Dirk
Auburn 866 Boattail Speedster VIN866A102
- 61xlch
- 61xlch
day by day new questions occur and I need your help again.
1. How are the inner door panels originally attached to the door frame? At my Auburn somebody nailed the leatherette to the bottom and to the top of the frame. At vertical sides there is no fixing. The inner screw for the outer door handle is correct?
2. My speedometer and possibly the Amperemeter seems to be not original, because of the twisted position and a different style.
Somebody knows more about these instruments? If somebody can offer me the right ones, please let me know.
3. Where is the VIN located? Cant remember....(oops)
Thanks in advance.
Andreas
