Oil- Detergent or Non?
- Brad J.
For me, this is the way to go. Back to using straight Rotella T as I have for many years.
- 61xlch
And even if this forum is just gonna dying, when the oil topic comes up - its back to live again... :rolleyes:
I believe there are as many oil solutions as there are collector cars.
Well, I change the oil in all of my cars and bikes once a year, in my Auburn I use a single grade SAE 40 Oil, especially designed for PreWarCars. I hope all needed additives are in there. And I do not race this car...
Best regards,
Andreas
Here's an extensive quote (not intended to bore):
" . . . accusations that uncaring oil companies are prepared to sacrifice our old cars on the twin altars of environmentalism and government-mandated mileage standards persist. Bob Olree, himself a collector car enthusiast, is the chair of the ILSAC/OIL Committee. In a 2004 SAE paper coauthored with Michael L. McMillan of General Motors Research and Development, Olree states that the test engines for the current oil designations are a Nissan 2.4-liter single overhead camshaft engine, and a General Motors 3.8-liter overhead valve engine. This latter engine has flat tappets. One of the tests, the Sequence IIIG test, is meant to simulate an overhead-valve engine with flat tappets in a truck pulling a load of cattle across a desert on a hot day. Current SM oils pass this test. Sounds good.
The authors of this paper also point out that SM oils contain about the same amount of ZDDP ? up to .08 per cent ? as the motor oils of the mid-1950s, and substantially more than the .03 percent included in the oils used in pre-World War II cars. High-load passenger car engines, like the powerful cars of the 1960s and 1970s, created a need for even more ZDDP up to .010 or .012 percent. It is this peak amount that has now been reduced to about .08 percent again. So, these engineers maintain, it is unlikely that the use of API-SM oils will result in catastrophic failure of our old engines. (They do caution that additives like GM's EOS are recommended for starting up flat tappet engines. And muscle car drivers appear to have cause to be wary.)
These engineers are experienced lubrication professionals, and their words should not be dismissed lightly. But technology moves on, at an accelerating rate. Current tests may not always tell us how well modern oils will serve our old cars over the long term. The authors of the paper agree that further reductions in zinc and phosporous are coming, and may provide proper protection only for newer cars. They even wonder aloud how much interest there will be in the future in protecting old and obscure engines.
So will current and future oils affect the ultimate longevity of our collector cars? At this writing, there may be some cause for concern.
Oil companies are under pressure to assist engine manufacturers in wringing the most miles per gallon out of their fleet averages, and appear to be, for now, willing to trade mileage for longevity. That is exactly the opposite of the interests of collector car owners. At the same time, the oil companies are aware of the effect of the removal of ZDDP from motor oils on older cars. Zinc-based additives are not the only way to achieve antiwear chemistry and most of the major companies are working on and incorporating substitute antiwear additives. But new engines do not require the level of antiwear protection that our older metallurgy and designs do. So it is possible that the antiwear package in future oils may never again reach the levels that we require." End of quote.
Note that the amount of ZDDP in current oils is about the same as in the 1950s. But it keeps going down, so I do worry about the future.
I have never seen an SAE recommendation for 1200 ppm of ZDDP for flat tappet engines. Can you tell me where this can be found?
The additive package in modern motor oil was designed to be a balanced recipe. Adding a couple of eggs to a cake recipe does not improve the cake. ZDDP in strengths of over 1600 ppm begins to attack yellow metals, like the ones in our cam bearings. Since you do not know the content of the ZDDP in the oil as purchased, how can you know how much to add? The Silver Ghost Association has commissioned an anti-wear additive that is NOT zinc-based, so it can be safely added to oil. Oil producers are working on non-zinc additives too. (Although if their current performance in the Gulf of Mexico is any reference, I'm not sure how far we can trust anything they say.)
If the tests I've seen are any indication there is, as you say, much variation in the qualities of gear lubes. Less so, I believe, in name brand motor oils.
I drive my Cord as much as anyone, and I want it to outlive me. I use either Shell Rotella T plus the SGA additive (expensive) or CCCA Classic Car Motor Oil (A bit less expensive.) Both of these are like chicken soup -- can't hurt.
And frankly, I published Ryan Stark's article to be provocative. Let's see what others say.
- Brad J.
K Clark
So this guy's lab has actual, real-world experience with lots of engines running with levels of ZDDP that get lower every year. If anyone has, they should have seen engine wear being caused by lower levels of ZDDP, right? Actually, no. His bottom line -- "oil is oil".
There are indeed lots of stories, on the Internet and elsewhere, about damage to flat-tappet engines on startup. I do not have the engineering or engine-building experience that would enable me to analyze these damages. But Mr. Stark's opinion cannot just be discounted.
Write to the Newsletter after you read the article. Responses will be published.
- Brad J.
Another option is Classic Car Motor Oil specially formulated for the Indiana Region of CCCA. Has special additives that help it cling to parts during long storage, plus the right level of ZDDP.
- JOEL GIVNER
JEG
For a dissertation on the use of modern motor oils in our cars see www.amazon.com/Keep-Collector-Al ... 569&sr=1-6 . It was written with ACD cars in mind.
And I've been paid -- I don't get any more money if you buy one!
- John Alkire
From what I have fond out, ZDDP didn't come into use until the late 1930's or early 40's, thus its absence from oils in our 30's cars should not be an issue. Most of the problems I have read about were in 50's engines (and newer) that were high compression, stiffer valve springs, etc.
Maybe somebody has some better info here.
John Alkire
Houston, TX
ACD Life Member
- Brad J.
- Steve Miller
- C.R.D.
The detergent vs non-detergent oil issue as you have probably noticed is a divided issue. Everyone will have to make there own decision. I use non-detergent oil in my older vehicles as the engines have never been rebuilt and without a full flow oil filter I believe it is best.
That being said Dollar General Stores, Walmart and Tractor Supply around here all sell non-detergent oil. I believe the closest Tractor Supply to your location would be Ashland, KY. Good luck in your search.
Carl
- Mike Dube
I am no oil expert either, but there's another viewpoint for you.
8-100A
- Greg Frownfelter
#75-115 should get you started, double check my number
it is readily available in the indiana whse and columbus
ohio should be the same
- Steve Miller
- Greg Frownfelter
should be available at your local NAPA store
our local owner stocks it for me
greg
More to the point, "detergents" in detergent oils are NOT cleaning agents as we understand them in Fantastic and 409. Sorry to be stubborn, but any petroleum engineer will tell you that they do not "scour" the engine. They work with dispersants to hold dirt in suspension until it can be filtered or drained. Yes, they do remove some accumulated sludge over time. So when you change to a detergent oil (or if you don't know what was in the car) change your oil at least 2-3 times every 500 miles. Oil is comparatively cheap. You should have no problem thereafter.
- Steve Miller
- 61xlch
as Michael already said: If your engine is not completely rebuilt and completely cleaned out - do not use modern detergent multi grade oils. It will break off all the dirt and carbon inside the engine and the oil pump will pump this around and around, thru bearings and so on....
In Germany there are different non detergent single grade oils available, especially made for use in old vintage engines. I use these oils since many years and never had any problem with oil leaks or smoking.
f.i. from Millers Oils (England) or Castrol Classic. Should not be too hard to find.
Best wishes
Andreas
- MICHAEL S SMITH
I DON,T CLAIM TO BE AN OIL EXPERT, ALL I CAN DO IS RELATE MY PERSONAL EXPERIENCE, IF YOU CHANGE FROM NON TO DETERGENT OIL IN A CAR RUN FOR A NUMBER OF YEARS ALMOST INVARIABLY THE ENGINE WILL START TO LEAK AND BLOW SMOKE, THIS IS BECAUSE THE NON DETEGENT OIL LEAVES DEPOSITS THAT BUILD UP THROUGHOUT THE ENGINE, SUCH AS THE RINGS ETC. THE DETERGENT OIL BREAKS ALL THIS DOWN AND IT GETS FLUSHED OUT.
IF YOUR ENGINE IS NEWLY REBUILT I,M SURE THERE IS NO PROBLEM WHATSOEVER, BUT IF IT HAS ALWAYS BEEN RUN ON DETERGENT OIL GET READY FOR LEAKS AND SOME VALVE GUIDE BLOW BY SMOKE ALONG WITH POSSIBLY SOME RING SMOKE UNTIL THE RINGS RESEAL THEMSELVES.
851 auburn phaeton
851 auburn sedan
810 cord westchester
812 cord custom s/c beverly
812 cord s/c cabriolet
812 cord s/c beverly
- Steve Miller
