Water leak, help
- Steve Miller
- oldbanger71
www.flickr.com/photos/josuereynoso/350597562/
if i got you right.
@ Mike : Have you ever tryed " Curil T " sealer ?
Here is the link:
www.scparts.co.uk/index/lang-2/l ... pl,x-a.htm
i use it without any paper or other gasket.
It works perfectly on my diff's and gearboxes. <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
812 310 121 S
auburn653 wrote: I always thought these old cars were like Harley's... they always leak!
Yes Troy, like the Dutch boy with his finger in the dyke.
- auburn653
mikespeed35 wrote: Hi Steve, I have been having a leaking diff. cover that I am on my fourth try at sealing it. The next thing I would try is no gasket and silicone sealer. Be sure the plate and cast iron are perfectly clean. I use a scalpel and a small pick to be sure every pit is clean and then wipe it down with laquire thinner till the rag dosen't get dirty when you wipe. Then apply the silicone as the instructions state. Let it cure fully before putting coolant back in. Of course use sealer of some type on the screws also. I give no gaurantee on this fix either, just something else to try. Remember I'm on my fourth diff. try.
I know what you mean Mike, I am on the fourth pass on the DR I am currently restoring. It is my belief that the lube makes it's way back through the threads on the bottom bolts that secure the cover. The threads in the housing are very short and will strip easly with any kind of torque. If is is not the threads, you might try a mill file across the diff and get the cover sanded flat at a machine shop. Some diffs leak, some don't.
- Steve Miller
- Terry
- Steve Miller
If it's cracked, you would have to take the plate off and clean out the interior surfaces. Best way (and messy) is to abrasive-blast it. Then coat the interior surface with epoxy. I hope the engine is out of the car...
- Steve Miller
- 61xlch
there are also some kind of steel-rubber-washers available, it will replace the old copper-asbestos-washer and work possibly better.
I use mostly Kent Siligasket on both sides of gaskets, this works always very good, even for the screw threads.
Good luck
Andreas
Steve Miller wrote:
auburn653 wrote: did you use a little silicone or thread sealer on the screw threads?
No, and I probably should have. They're all new SS screws too, and that's where most of the trickling is coming from, around the screws. I think I'll take each one out and try that.
The 1934-1936 Auburns that had the side plate cover; each bollt was sealed with a copper asbestos washer. Part # 11S1. I'll bet the early engines used the same.
- sds1861
Those screw holes go all the way through into the water jacket. They will leak forever if the treads aren't sealed. You need to drain the block, remove all the screws and blow out the screw holes until they are bone dry. Then when replacing the screws, give the threads of each screw a generous coating of gasket sealer with a small brush. I used that red permatex in the aerosol can. I sprayed the sealer into the plastic cap and dipped a small paint brush in the liquid to coat the screw threads. I would also put sealer on the side of the gasket that mates to the block. I have never had good luck with dry gaskets on anything.
You will probably still have some slight seepage from some of the screws as you start driving the car. Slight additional tightening may be necessary. If you add a bottle of Bars Leak to the antifreeze when you refill the system, it will eventually take care of any slight seepage.
Best regards,
Steve Stevens
Then I ommited the gasket and just used Permatex Ultra Black on the gasket surfaces and tightened everything in place. I also used that Permatex Indian Head stuff on the bolt threads, but I think that was overkill. A hydaulic machinest that I know always uses the Ultra Black on his high pressure plates, and it works great.
- mdsbob
But, typically the threaded fasteners are not part of the seal. The gasket should provide a seal between the source and the threaded hole.
I noted you used "Indian Head shellac". I think #2 Permatex would be a better choice for a gasket sealer.
Often permatex applied between the sheet metal piece attached to the block is sufficent and the gasket only to the machined block surface will seal. If you are having trouble with this apply permatex to both surfaces.
I would probably try a new gasket and clean the cover well and use permatex.
Bob
- Steve Miller
- auburn653
- Steve Miller
- Terry
- Steve Miller
