1934-36 Auburn Dual-Ratio Rear Axle
30 Jul 2010 12:17 #17424
The book lists five different ratios for the single speed but only one for the D/R. The 51-10 was used in 1934 and 1935 to 851 s/n 2745. After that the 43x10 was used. I believe I have seen other ratios, but don't see them in the book.
Yes, the axels are different sizes, they are all like that. Auburn used one seal p/n E62686; snug on the LH not so much on the RH. Modern neopreme seals are much more forgiving than the older felt seals.
Replied by Curt Schulze on topic Re: 1934-36 Auburn Dual-Ratio Rear Axle
Terry wrote: How many different gear ratios were there on the Dual-Ratio 34-36 Auburns.
Mine has a 51-10
The pass side axle shaft at the inner seal measures 1.375 or 1 3/8"
The driver side at same spot measures 1.406 or 1 13/32"
Has anyone ever seen this before.
All comments appreciated.
30 Jul 2010 04:37 #17423
Replied by mikespeed35 on topic 1934-36 Auburn Dual-Ratio Rear Axle
Yes, I had to use two differant size seals also. The differance has to do with the speedo drive. My ratio is 43x10 which I'm told is correct for Speedster.
- Terry
29 Jul 2010 19:09 #17420
by Terry
1934-36 Auburn Dual-Ratio Rear Axle was created by Terry
Mine has a 51-10
Mine has a 51-10
