Head Removal
- Neal Ziff
Neal
_________________
1930 8-95 Cabriolet
- oldbanger71
I have no knowledge about Auburns specificley, but just general knowledge and expirience with Cords, so i would not dare to give in a guessed torque-figur.
I just give my thoughts in and when somebodey knows better i aprisiate if he or she is correcting me for my education and avoiding ill leaded thoughts, so go on
812 310 121 S
- 61xlch
Best wishes
Andreas
- oldbanger71
812 310 121 S
- Neal Ziff
Neal
Neal
_________________
1930 8-95 Cabriolet
- oldbanger71
@ Mike : Sorry, your right i have mixt the words, english is not my mothertongue, should have better gone to bed insted of reading in ACD forum......... <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
812 310 121 S
- 61xlch
oldbanger71, Philipp wrote: When you have reground the surfaces, make sure that the pistons don't hit the valves, even if the head is torqued down again after some miles.
The gasket should be increased at least the thickness which was ground away on both surfaces plus the original gasket thickness.
Philipp: I guess you are talking about OHV-engines? Hard to imagine how the valve hits the piston in flathead engines.
On the old flatheads this is not that critical, a bit more compression ratio should be compensated by todays higher octane fuel, isn?t it?
Best
Andreas
- oldbanger71
Do not use stainless steel studs, since the headstuds are usually special steel.
Stainless steel studs tend to result in overtorqueing and often in braking with time, since they are more brittle.
Use correct new headstuds with coppergrease and youll be fine.
812 310 121 S
- Neal Ziff
I was going to have the head checked for cracks and then have it blanchard ground to make sure it's flat. Thanks for the suggestion about replacing the studs - I'll take a good look at them as I clean things up. Any other suggestions while I've got it opened up? I appreciate all the tips I can get.
Neal
Neal
_________________
1930 8-95 Cabriolet
- Neal Ziff
Thanks for all the help,
Neal
Neal
_________________
1930 8-95 Cabriolet
- Terry
I don't like the idea of lifting the head with a chain welded to the spark plugs as they are aliminum and can strip the threads quite easily.
- W. E. Snelson
Next thing that comes to my mind is to make or rig a puller. I am unfamiliar with the layout of the Auburn head though. Anyone have additional thoughts?
- Neal Ziff
Tom - I tried the dead-blow hammer, but don't notice any movement.
Is a wide blade chisel along the gasket seam a bad idea?
Neal
_________________
1930 8-95 Cabriolet
Ooooooooooooooo! I like that !!! Great idea.
- Terry
Reinsert the spark plugs only, (no wires)
Crank engine over a few revolutions and the head should come free on its own. Remove bolts and take head off and clean as needed.
This works for me. No hammering or tapping of any kind and no damage. Good luck
As is stated in the Hippcratic Oath, "First do no harm." Be gentle in all you do.
If you find it necessary to "bump" the head to break it loose, and that's likely, use a plastic dead-fall hammer to do the bumping. Harbor Freight has these cheap. If you're as old as I am, you might use an old fashioned cast lead hammer. I strongly suggest that you do not bump with a steel or iron hammer--these will be more likely to create a crack in the casting that is the head.
Use a heavy "bumper" rather than a "light" one, ie, 4# rather than 1#. "Heavy" moves things, "light" bends (breaks) things.
Keep us advised of your progress!!
[/list]
- Neal Ziff
Before I try anything stupid, what suggestions do you have to dislodge the head?
Neal
Neal
_________________
1930 8-95 Cabriolet
