- Thank you received: 25
Fuel pump diaphragm
- E L
- Steve Miller
www.pspglobal.com/viton-selecting.html
www.robinsonrubber.com/pdfs/NitrileRubber.pdf
- sds1861
Good job. Sounds like you are in business with your fuel system.
Regards,
Steve S.
- Steve Miller
- sds1861
Your cam lobe should be fine with that low mileage on it so the pump is the culprit. I would take it back off the car, disassemble it and check everything. Here are a couple of other things to try if you haven't already done them.
1) When replacing the top cover of the pump, you should start all the screws about three turns and then push the lever all the way in and hold it there while tightening the screws the rest of the way. This procedure is outlined in the factory service manual. Without doing this, the new diaphragm is too tight and restricts the movement of the lever stroke.
2) Don't use too thick of a gasket when mounting the pump to the engine block. Thin cork is OK as it compresses. Too thick of a gasket cuts down on the effectiveness of the cam lobe.
Regards,
Steve S.
- Steve Miller
- sds1861
Was the car running on the fuel pump before you took it off for the rebuild? If so, then you have done something wrong on the rebuild. If not, then you need to check the fuel pump lobe on your cam shaft. It could be worn to the point that it won't properly cycle the pump. Another thing, did you resurface the shoe that contacts the cam lobe when you rebuilt the pump? If so, you may have removed just enough metal to prevent proper pump action. When working properly, the sediment bowl on the pump should start to fill with gas in just a few revolutions of the engine at cranking speed. I have a spare pump that I rebuilt and test ran on my 1932 model. I would loan it to you to try on your car.
Regards,
Steve Stevens
- Steve Miller
- Steve Miller
Thanks again
- Joel
- Steve Miller
- Joel
www.mcmaster.com/#1890t12/=8lrajb
Good luck! Joel
- Steve Miller
