Carter carbs
- 61xlch
This car came originally in 1931 in black with red stripes. This strikes me - I would love it.
Probably I will try a very sensitive restoration without renewing everything. Just some body work and a new paint....?
Yep, the air cleaner is on top of my todo-list for this winter.
Best
Andreas
- Mike Dube
61xlch wrote: ...is this a Carter BB1?
Its on my 8-98 and it workes very good.
Regards
Andreas
I also cast my vote with Mike & Bob...drive them. On another subject, I'd put an air filter on it. Sure the 8-98 & early 8-100 models didn't usually come with one, but it keeps a lot of grit out of the engine. Originals can be hard to find, but if you visit a motorcycle shop, I'll bet they can fit you with a foam type that will do the job.
8-100A
- Rum-Runner
Just one drivers opinion.
- 61xlch
mikespeed35 wrote: Hi Andreas, About the picture you posted of your carb. If the rubber hose I see and the plastic fuel filter is next to the exaust manifold I would move it if you don't want vapor lock or a fire. The hose should also be fuel injection hose that will stand up to alcohol. Better yet use metal fuel line.
Thanks for your advise, you are absolutly right. I will do so this winter.
A copper fuel line with a loop should do the job
Basically the car is still in the same shape I bought it 2 years ago. My first intention was to restore it, but after I did not find the time for doing this until now, I made only a maintanance routine service and drove it this year few times (may be 800 miles) without any problems - to my biggest surprise. Just today we had a nice trip to a classic car event near Berlin.
I already owned 5 different classic and vintage cars, but never before drove a car in this condition. With a poor paint job even on the carb!, plastic fuel filter and rubber hose, without window seals and other "special options". Shame on me. But its a lot of fun to drive it and where ever I go people are pleased to see this car and most people discourage me from a restoration.
I am still undetermined, but anyway I will try to improve it from time to time.
Best,
Andreas
Good catch, Mike!!!!
Fire sucks.
- Steve Miller
- Steve Miller
Thanks again
- 61xlch
Best
Andreas
- sds1861
Yes it is. The Carter BB-1 is an aftermarket replacement carburetor for the Schebler TX and the Stromberg URO-2 as well as others. It will work fine on an 8 cylinder Auburn and has an adjustable main jet (that knob with the cross pin at the bottom of the bowl). The two above mentioned carburetors have non-adjustable main jets that are sized specfically to each engine application. Most BB-1s that I have seen and owned are cast iron, but I think the later ones were produced in aluminum.
Best regards,
Steve Stevens
- 61xlch
- sds1861
Your needle valve in the carburetor inlet is not closing properly and allowing the carburetor to overflow. You can easily rebuild this carburetor without a store bought kit. Give me a call at 812-477-5916 and I'll walk you through the process.
Regards,
Steve Stevens
- Steve Miller
- pwright
- oldbanger71
www.carburetor.ca/
www.carburetor-parts.com/servlet ... Categories
www.vintagespeed.com/carbs.htm
www.jdheritage.net/DeerelyDepart ... _Index.asp
<!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
812 310 121 S
- Steve Miller
