Sparton SOS Horn Paint
- IndycarBruce
12 Dec 2010 02:38 #18743
by IndycarBruce
Replied by IndycarBruce on topic Sparton SOS Horn Paint
Andreas,
Thank you for the information.
Bruce
Bruce
- 61xlch
09 Dec 2010 19:33 #18716
by 61xlch
Replied by 61xlch on topic Sparton SOS Horn Paint
Powder coating was definitely not used on Prewar Cars. It became popular for car restauration in the 80ies!
You will not need special heat resistant enamel. Simple spray paint is resistant enough.
Good luck
Good luck
- IndycarBruce
06 Dec 2010 23:52 #18670
by IndycarBruce
After checking the internet, it seems like powder coating wasn't used until the late 40's or early 50's.
Can anyone at least confirm Auburn didn't use it on under the hood parts?
- IndycarBruce
06 Dec 2010 20:30 #18667
by IndycarBruce
Sparton SOS Horn Paint was created by IndycarBruce
Regarding refinishing a Sparton SOS horn for a 1929 mounted to the engine- should it be powder coated or spray painted? If spray painted, does it need to be high temp enamel?
The color is black. Appears to be gloss enamel.
