Gasket material - silver headlamp
  • Curt Schulze
02 Feb 2011 13:28 #19140 by Curt Schulze
Replied by Curt Schulze on topic cork
It is true cork was used in the headlights when new. I have also seen round cotton rope that was original from the factory.
I choose the neoprene tubing for the same reason that I use modern seals in place of the leather that was originally supplied.
It is my opinion that modern materials are superior to the 70 year old technology. If you can put in in your car and it cannot be seen, use it.
  • mikespeed35
01 Feb 2011 23:16 #19137 by mikespeed35
Replied by mikespeed35 on topic Gasket material - silver headlamp
I use the cork gasket material available from auto supply stores such as NAPA. Cut to the size you need. It is available by the foot.
  • Visitor
  • Guest
01 Feb 2011 22:10 #19136 by
Replied by on topic gasket
The reflectors should have small groove the size of the cork, that would hold the cork in place until, the lens puts pressure against it, from then on it cannot move.
K Clark
01 Feb 2011 06:26 #19135 by [email protected]
What would you use to hold the cork in place? Maybe a gasket seal?
Would it tarnish the silver?
Also if the cork got wet from rain, could hold the moisture.
Tom
ACD Member
  • Visitor
  • Guest
31 Jan 2011 12:51 #19129 by
Replied by on topic silver reflectors
Yes cork was the original headlight seal very easy to use very easy to get.
My 2 Cents
K Clark
  • mikespeed35
31 Jan 2011 02:18 #19125 by mikespeed35
I believe cork was the original material.
30 Jan 2011 23:11 #19124 by [email protected]
Thanks Curt.
Good idea. I know the plastic will not react with the silver.
Thanks again,
Tom Roche
ACD Member
  • Justin Kerns
29 Jan 2011 00:59 #19112 by Justin Kerns
Replied by Justin Kerns on topic Gasket material - silver headlamp
Tom - Welcome and lets see more photos of that great Salon Sedan!
Justin
Justin
1932 Auburn 12-160A Sedan
1933 Auburn 12-161A Sedan
  • Chris Summers
29 Jan 2011 00:49 #19111 by Chris Summers
Replied by Chris Summers on topic Gasket material - silver headlamp
Good to see you on the Forum, Tom. Hope the car and yourself are well.
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
  • Curt Schulze
29 Jan 2011 00:19 #19110 by Curt Schulze
Replied by Curt Schulze on topic Lenses
Go to your local hobby shop and invest in model airplane fuel line. It compresses nicely & seals air tight.
28 Jan 2011 23:31 #19109 by [email protected]
I had my headlight reflectors silver-plated. Now I need to seal the glass lenses onto the reflectors. I'm looking for some kind of sealant or gasket material which will not corrode or discolor the silver.
I'm aware that rubber-based materials can give off sulphur which corrodes silver plating.
Has anyone used RTV for a similar application?
Or has anyone found a suitable material for sealing headlight reflectors to lenses after silver plating?
ACD Member
