1933 Auburn 8 105 Engine questions
- nickg112
06 Sep 2012 23:57 #23432
by nickg112
Replied by nickg112 on topic 1933 Auburn 8 105 Engine questions
Thanks for the information. I gave John a call and he provided some great information. He did not have the parts but gave me some contacts ad some ideas.
06 Sep 2012 21:41 #23431
Replied by mikespeed35 on topic 1933 Auburn 8 105 Engine questions
I agree with Joel, John is the Man.
- JOEL GIVNER
06 Sep 2012 17:55 #23427
by JOEL GIVNER
JEG
Replied by JOEL GIVNER on topic 1933 8-105 salon
Give John Forsythe a call at Fremont NAPA auto parts in Fremont, Ohio. He should be able to get the parts you need since he has a 1932 Auburn 8 and what you are looking for are the same.
JEG
06 Sep 2012 16:45 #23426
by Tom_Parkinson
Replied by Tom_Parkinson on topic 1933 Auburn 8 105 Engine questions
Hi,
Hagen Hiway Auto Parts' 1933 Auburn page shows that they will rebuild your distributor, that the original Champion Spark plugs are Unattainium, and that Autolite substitutes will fit.
They are in Pullayup, WA. A few weeks ago I spoke with "Rick," who matched up an alternate, but workable and affordable, distributor cap and rotor for my 812 Cord. ( I bought a "5 life-times" supply of these parts.)
This is their 1933 Auburn page:
www.hagensautoparts.com/1933/AUB ... c+GC-8cyl/
Good luck with your project.
- nickg112
06 Sep 2012 15:25 #23425
by nickg112
1933 Auburn 8 105 Engine questions was created by nickg112
I have a 1933 Auburn 8 105 Salon Dual Ratio Cabriolet. Can anyone tell me what spark plugs to use and where would be a good source. I also need wires and maybe distributor components.
My distributor is a 660Z Delco Remy. Off the one side the Electrolock Distributor Connection assembly is damaged and I do not have the lock cylinder with cable connection. I am sure that I could change this and use a different ignition set up but I would like to set up original if possible.
Any Help is greatly appreciated. Thank you
