Auburn 8 Engine light blue?
- 61xlch
I will stay with the original hardware as much as possible, even if not everything ist still original. But it will be hard enough finding the big and important parts I need, so I doubt I will be able to locate also original hardware.
Its really a masochistic job restoring an american classic like an Auburn in Germany. I dont have the connections, there is the language and time difference - what makes phone calls difficult, and last but not least the shipping costs and custom fees and taxes.... :rolleyes:
I have been buying my engine paints from Stan Gilliland and have been very pleased with paint quality and color. www.auburncordparts.com/Auburn_C ... /Home.html
Of the original engine tags and dataplates that I have, about half are lined up nicely. (they nust have used a tool to gang punch them) and the other half are the durnken sailor variety.
And, Curt and I always joke about the drunken sailor that stamped the numbers on the plates, engines, and frames (rare to ever see a number all lined up in an even row ? some do exist though). This engine plate seems a fine example of what is commonly found.
- 61xlch
RandyEma wrote: Engine rebuilders had std colors they used when and after they rebuilt an engine to help id that they did the work . The engine from a rebuilder in S. Calif would have hot tanked the motor so you would have no old color remaining. Randy
This sounds very reasonable. I will go for the original olive green. Unfortunatly I already purchased the Bill-Hirsch paint, which seems to be wrong.
BTW, Randy: I found a cent coin from the early seventies in the RH frame rail (probably a left over from the accident - see my restoration thread). Is it yours? If you like I will send it back to you <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
- 61xlch
Curt Schulze wrote:
GIVNER wrote: Why wouldnt you use the original engine tag??
AMEN to that Joel!
I will use the original tag, of course.
I purchased the repro 3 years ago together with a new (original missing) body tag. I only wonder about the different design.
AMEN to that Joel!
- JOEL GIVNER
JEG
- 61xlch
auburn653 wrote: I would tend to think this was a repaint of a rebuild, not factory, as the Lycoming name plate is painted over.
May be, but in this case the old paint has been removed perfectly by sand blasting. And I wonder why anybody painted the engine blue?
BTW: The new repro engine tag is different. Not original? Another year?
- auburn653
I would venture to say originally, the engines were painted prior to id tag being applied.. otherwise, we wouldn't ever see any brass with black background.
- 61xlch
I only found a light blue color everywhere. Not the smallest sign of olive green.
Anybody knows if there were Auburn engine painted light blue original?
Possibly this engine comes from another year or another model or make?
Andreas
