1931 Auburn Sedan Distributor Question
As everyone mentioned, the rotational play is due to the counterbalance weights.
- olvette64
TR
- 61xlch
Possibly you are talking about the "back and forth"-play of the rotor, caused by the auto advance mechanism?
Andreas
- silverghost
ie:
severe contact point bounce
incorrect & eratic ignition point dwell & timing
severe misfiring
poor & incorrect ignition advancement
premature breakage of points
center ignition rotor possibly hitting inside of cap tower contact areas.
In short~
Your engine will never ever run very well at all with 1/4 inch of top shaft side play , and the resulting contact point cam, side play & severe ignition point bounce.
It sounds like the distributor shaft in this engine ran for many years without proper oil, or light grease, lubrication at the top shaft bearing bushing .
There is usually a felt wick to retain some oil, or light grease, at this top shaft bushing area that needs periodic lube.
It was most likely never lubed~
In the photo above I believe I see a grease cup unit on the distributor's top/side that shound be filled-up with light grease & given a slight clockwise turn-in every so often to force some lube into the upper shaft bushing.
I would look for another old distributor in far better condition ; or at the very least have new bronze bearing bushings installed in your old distributor unit & perhapps also a new distributor shaft as it may well be severly worn also.
- olvette64
- 61xlch
olvette64 wrote: Thank you to everyone for their reply on my distributor. I plan to use the original distributor with the dual points. Are the points, cap, rotor and condenser still available through NAPA or will I need to find new old stock? If they are available does anyone have any part numbers or a place they recommend to buy them. I also noticed that my distributor shaft has some play in it about 1/4 inch. Is this normal or should it be solild?
there is just a complete set at Ebay:
... IT&vxp=mtr
Regards
Andreas
- olvette64
- DavidK
- Ivor
I use a similar method to Pat, A machined perspex ring marked exactly at 45 degrees, the pointer bushing held on distributer shaft with grub screw, perspex ring a firm fit over housing spigot. Use a multimeter or rig up a light bulp. I would check you have the firing order correct as it should fire on all eight cyl even with the timing a bit out.
- Pat Leahy
- Thank you received: 28
I use the George Arakalien method, a round piece of paper marked in 45 degree segments, a bent piece of wire for a pointer, and a multimeter.
Pat Leahy
- sds1861
Your car will run fine on the original dual point distributor. You just need to find a member who has a synchronizing tool and is willing to do it for you. You will have a lot less problems, now and later, By just getting your original distributor right.
Steve Stevens
- olvette64
I have a 1931 Auburn Sedan with the Lycoming engine that I am restoring. I am trying to get it running and the points were pretty rough. It has the delco remy dual point distributor. I do now want to change the synchronization since I do not have the tool to synchronize them. It acts like it is not hitting on all cylinders. Does anyone know of a good replacement single point distributor that will fit my engine. I believe it will be easier to get it running with a single point distributor. Also does anyone know any part numbers for the replacement points, cap, rotor, or even distributor? Any help will be greatly appreciated.
