Gauge Panel
- 61xlch
13 Apr 2013 20:19 #25001
by 61xlch
Replied by 61xlch on topic Gauge Panel
Randy,
yes, thats the way to go. Same as Brads.
Mine must have been modified.
Andreas
Andreas
- Thank you received: 91
13 Apr 2013 19:21 #24999
by RandyEma
Replied by RandyEma on topic Gauge Panel
Andreas .The outer edge is satin chrome(butler finish) the inner is satin black. Randy
- 61xlch
12 Apr 2013 19:37 #24995
by 61xlch
- Brad Hoskins
- Thank you received: 11
12 Apr 2013 06:29 #24992
by Brad Hoskins
31 8-98 cabriolet
Replied by Brad Hoskins on topic Gauge Panel
Andreas
I think the 8-98A had engine turned inserts top and bottom on the flat sections.
The 89-8 had a black background on the top and a grey background on the bottom . The raised bead appears to be chrome plated.
Here are pictures of my unmolested 31 dash panel ( at least I think it is 31). The grey portion has almost a raised foil texture to it.
Brad
Brad
31 8-98 cabriolet
- 61xlch
21 Mar 2013 20:51 #24827
by 61xlch
Regarding dash panel:
Does anybody know, how is the original finish of the dash panel frame of a 1931 8-98?
Mine was painted grey, looks totally stock. But all cars I see at pictures have a chromed frame!
Didn?t find any remaining signs of chrome at mine.
Possibly there is a difference between 8-98 and 8-98A?
Andreas
Andreas
- Mike Dube
21 Mar 2013 15:12 #24826
by Mike Dube
8-100A
Replied by Mike Dube on topic 8-100 dash panel
There is at least 1 difference between early & late '32 eight panels. My late '32 has a flat panel with the crosshatched pattern painted (silkscreened) on. A friend's early car has the pattern stamped into the metal as Randy stated. This is the better one to have if you like shiney, as I can't polish mine. While my car was restored some years back, the dash remains original.
8-100A
- DavidK
20 Mar 2013 21:02 #24825
by DavidK
Replied by DavidK on topic Gauge Panel
Thanks Randy,
I sent you a PM.
Dave
I sent you a PM.
Dave
20 Mar 2013 17:59 #24824
by RandyEma
hello. 8-100 is a stamped diamond pattern 12-160 is a flat turned panel. Randy
- DavidK
20 Mar 2013 16:32 #24823
by DavidK
Gauge Panel was created by DavidK
Does anyone know what type of gauge panel a 1932 Auburn 8-100A Cabriolet should have. The parts book for the 8-100s shows two different ones. One has a diamond pattern. I don't know what the other type is. Did the 12 cylinder cars have a different pattern? What cars used the engine turned pattern? I have several Auburn books but few pictures of the dashes. I don't have a 12 cylinder parts book.
Also, the details and discription book says the Customs have a walnut finish instrument panel ( dash board ) and garnish moldings. Is this just on the closed cars?
Thanks for the help.
