Auburn Elecrical Questions
13 Apr 2013 19:24 #25000
Replied by johnmereness on topic Auburn Elecrical Questions
I converted it to a starter solenoid - the problem with the Startix is that if you stall the car and it tries to restart itself most people are not use to such and get all flustered (ie. not an intuitive process) - and that is when you rear end the car in front of you.
- nickg112
12 Apr 2013 01:21 #24987
by nickg112
Replied by nickg112 on topic Startix
Got the car running today with Startix. The Startix now works perfectly. Next project is wiring harnesses and brakes.
- Mike Dube
11 Apr 2013 13:48 #24984
by Mike Dube
8-100A
Replied by Mike Dube on topic Auburn Elecrical Questions
The folks @ Fremont Auto Parts know these cars very well.
8-100A
- nickg112
11 Apr 2013 02:36 #24980
by nickg112
Replied by nickg112 on topic Auburn Elecrical Questions
Thanks for the help. I will call them.
- red.auburn851
10 Apr 2013 13:04 #24978
by red.auburn851
Replied by red.auburn851 on topic Auburn ignition
I rewired my car last year and hooked back up the Startex, works great. I did rewire my car exactly to the wiring diagram, this is important. My engine was rebuilt by Fremont Auto parts, 419-332-8296, Jason is great there, and we all know John Forsythe who works there. They rebuilt my Startex, the generator, I rebiult my Startex switch. My car started yesterday on the second crack, after 4 months of winter rest, so it does work. Now for the but, as I understand it, you want the 2 solinoids working in the Startex and you want the adjustment screw just so. I am not a mechanic, but as I understand it, you wnat the bits working just so. Fuel pressue is important, so I use an electric pump to suppliment my mechanical, this helps prevent vapor lock on hot summer days, I keep the battery turned off when parked, and so far, so good. Good luck.
- nickg112
10 Apr 2013 02:17 #24975
by nickg112
This is what I just noticed on my ignition. I have a 3 terminal ignition switch with Accessory, Coil and Ammeter. I see electrical schematics for both 3 and 4 terminal ignition in my literature. I believe the 4 terminal is for the electrolock. I no longer have the electrolock so I am assuming that my 3 terminal ignition is correct. There is no Startix terminal or Start terminal on my ignition. Can you tell me which wires are going to each terminal on the ignition? I am assuming that you turn the switch to the right and then all the way to the left after the car starts. Is that correct? Is it possible that my ignition switch is not correct?
- nickg112
09 Apr 2013 13:36 #24969
by nickg112
I am convinced. I am going to change my plans and use the Startix. I like your idea on how to disengage. That was my concern. I may have another question as I try it out. Thanks
08 Apr 2013 22:29 #24960
Replied by mikespeed35 on topic Auburn Elecrical Questions
I use my startix with no problems. I start it on startix and then turn the switch to ign. so the startix won't self start. Thats a 35 Auburn.
- Mike Dube
07 Apr 2013 23:19 #24952
by Mike Dube
8-100A
Nick,
I think you'll find most of us still have the Startix hooked up and have no major problems with it. Are they a necessary thing? No, but others besides A, C & D used them, they are not an unknown quantity.
8-100A
- nickg112
05 Apr 2013 22:18 #24937
by nickg112
Auburn Elecrical Questions was created by nickg112
I finally got my 1933 8-105 Cabriolet running. It runs great. The engine was rebuilt thirty years ago and never started. It really sounds strong. I am now looking to do the electrical. Although I have the Startix in the car, I have been told that they are more of a nuisance that something that is practical. I have deided to bypass the Startix system. Here is how I am proceeding. I have some questions next to each numbered area. I welcome comments as well as answers to my questions:
1) I am using an old style Ford 6 Volt Solenoid. It is wired as follows: Battery to Solenoid and Solenoid to Sarter. No issues here.
2) Generator and Relay: Wire from Ammeter to Generator. There is also an internal wire going to the opposite side of the Generator/Relay. Is that all that is needed on the generator? Any additional grounds? Any other wires?
3) Ignition: Is the Ignition for the Startix system usable for this type of set up. I am planning on adding a starter button. Not sure if the ignition needs to be changed.
I have a couple of additional questions but will post separately. Thank you
