Auburn Gas Linkage question 1933 Auburn 8-105
- DavidK
09 Apr 2013 15:43 #24971
by DavidK
Replied by DavidK on topic Updraft linkage hookup
I know you have a downdraft carburetor but here is how it is hooked up on my updraft if that helps at all. The throttle rod is on the other side of the carburetor. You might find a good picture of your carburetor on the internet. Dave
[img][img]http://i1251.photobucket.com/albums/hh550/32auburn/StrombergURO-2002_zps6fe2bff7.jpg[/img][/img]
- nickg112
09 Apr 2013 13:35 #24968
by nickg112
Replied by nickg112 on topic Auburn Gas Linkage question 1933 Auburn 8-105
The problem I am having is I do not understand how both the lever and gas pedal can be connected to the same point on carburetor. Can you please explain or show a photo on how the gas pedal and push lever are connected. This may be a dumb question but I truly do not understand exactly how the two connections are. Thanks
08 Apr 2013 22:26 #24959
Replied by mikespeed35 on topic Auburn Gas Linkage question 1933 Auburn 8-105
A hand throttle is just that. You engage it by hand and you have to disengage it also. It dosn't disengage when you push on the gas. At least thats how 35-36 Auburns and L-29 Cords work.
- nickg112
07 Apr 2013 23:16 #24951
by nickg112
I understand that it is a hand throttle. Just not sure how it disengages when you step on the gas. I am sure that the hand throttle does not continue to go in and out when the gas pedal is depressed. I cannot find in my literature how it is hooked up.
- Mike Dube
07 Apr 2013 23:08 #24950
by Mike Dube
8-100A
Replied by Mike Dube on topic Auburn Gas Linkage question 1933 Auburn 8-105
It's not a cruise control, basically just a hand throttle. Not sure how it hooks up to your downdraft, tho Mason can probably help with that.
8-100A
- nickg112
05 Apr 2013 22:22 #24938
by nickg112
Auburn Gas Linkage question 1933 Auburn 8-105 was created by nickg112
Where and how does the gas pull button located on the dash, hook up to the carburetor? Does it hook up in a different location than the gas pedal linkage? Does it disengage when you step on the gas pedal? I know the intent, just not sure of how it connects. Can anyone help? A photo would help. Thanks
