Auburn Distributor bolt
12 Apr 2013 02:22 #24988
Replied by mikespeed35 on topic Auburn Distributor bolt
Very similar to L-29 Cord only L-29 has a flat washer below the spring for the advance arm to slide more easly.
- nickg112
11 Apr 2013 13:01 #24983
by nickg112
Replied by nickg112 on topic Auburn Distributor bolt
Thank you so much. Great photo
- Ivor
11 Apr 2013 10:31 #24982
by Ivor
Replied by Ivor on topic Distributor setscrew and spring
[img][img]http://i1159.photobucket.com/albums/p633/ivor6/IMG_2338.jpg[/img][/img]
Hello nick, This is a photo of our 8-77 might be similar, photo bucket failed so tried image shack.
Hope it helps.
Hope it helps.
- Ivor
11 Apr 2013 08:11 #24981
by Ivor
Hello Nick, some photos of our 8-77 distributor setscrew and spring, might be same or similar.
- nickg112
05 Apr 2013 22:26 #24939
by nickg112
Auburn Distributor bolt was created by nickg112
I am not sure what the hold down bolt for the spark advance on the distributor should looks like for my 33 Auburn 8-105. Is there a special bolt with spacer? It seems like there needs to be enough tension to hold the distributor down while allowing adjustment for spark advance. I know that i have the wrong bolt now. Can anyone help? Thank you
