Master Cyl.
15 Apr 2013 17:59 #25016
by Tom_Parkinson
Replied by Tom_Parkinson on topic Master Cyl.
Hi,
I have sleeved several cylinders with brass, but now I send them out to www.brakeplace.com for sleeves done with stainless steel, plus new kits installed.
The decision to have a sleeve installed comes from whether or not the cylinder wall has been pitted by water damage. Honing will not take out pitting, and the alternatives are 1) a new cylinder, or 2) sleeving. If there is no pitting, then honing the cylinder and installing a new kit makes a good fix.
15 Apr 2013 16:55 #25015
by ilikescars
Replied by ilikescars on topic Master Cyl.
Mike. I've had pretty good luck just honing out the cyl, bench bleeding and install in car. Works great
14 Apr 2013 19:13 #25011
Master Cyl. was created by mikespeed35
In case any one is interested the master cyl. repair kit is available from NAPA for under $20. Master cyl. kit no. 2. Apple Hydraulics is charging $80. to resleeve in brass and $105. for S.S.
