Rear Axle Seals and Shims 1932 Auburn
12 Jul 2018 03:20 #34955
Replied by mikespeed35 on topic Rear Axle Seals and Shims 1932 Auburn
The manual says anything more than .005 should be tightened up.
- ttcinc
11 Jul 2018 11:51 #34954
by ttcinc
Replied by ttcinc on topic Rear Axle Seals and Shims 1932 Auburn
Thank you for the Info. I'm going to make a new part to retain the Lip seal. I think 005 would work on the end play. This I believe is for Expansion when the rear end gets warm so a few thou loose would be better than tight.
11 Jul 2018 03:57 - 11 Jul 2018 03:58 #34952
The specs. for the 35-36 Auburn are .003 to .005 end play measured with a dial indicator. Don't know if it is the same for 32. I measured the bore and housing size and used a lip seal. You may have to fabricate a collar for the OD. Both sides do not have the same size on my car so be sure and measure both.
Last edit: 11 Jul 2018 03:58 by mikespeed35.
- ttcinc
10 Jul 2018 19:10 - 10 Jul 2018 19:28 #34943
by ttcinc
Rear Axle Seals and Shims 1932 Auburn was created by ttcinc
Could someone help me out with my rear axle seals? I am doing my brakes and I have a lot of grease in the drums. So I took apart the rear brake plate assembly and found some shims and a tattered seal. Is this supposed to be a leather seal or rubber? Can it be replaced with a lip seal? The shims I imagine are to set the axle bearing thrust play. Does anyone know the spec in axle thrust so I can make sure it is shimmed right? Thank you for all your help.
Last edit: 10 Jul 2018 19:28 by ttcinc.
