INTERIORDOOR HARDWARE
- A.S. KOLLER
20 Apr 2022 23:01 #45204
by A.S. KOLLER
Replied by A.S. KOLLER on topic INTERIORDOOR HARDWARE
Thanks for trying Pete, I appreciate it.
Steve
Steve
18 Apr 2022 12:39 #45196
by pete kelly
Replied by pete kelly on topic INTERIORDOOR HARDWARE
Hi Steve
I have 5 but they all need plating so Stan is the way to go.
Looking forward to Auburn!
Pete
Pete
- A.S. KOLLER
16 Apr 2022 19:02 #45194
by A.S. KOLLER
Hi Pete,
Sorry for the delay in getting back to you but I have been off the grid for a while.
Stan has new escutcheons for $ 26 each but if you have four good ones, that don't need plating, that you want to part with let me know.
I also did locate an interior door handle.
Thanks for your help
Steve
Steve
06 Apr 2022 12:59 #45132
by pete kelly
Hi Steve
Did you find enough of the proper interior escutcheons?
Pete
Pete
- A.S. KOLLER
31 Mar 2022 17:34 #45110
by A.S. KOLLER
Thanks George and Terry,
I was really surprised as that it was the smaller escutcheon as the larger one sort of matches the handle on the window crank.
By any chance do any of you have extra escutcheons and or an interior door handle?
Steve
Steve
- Thank you received: 305
16 Mar 2022 01:31 - 16 Mar 2022 01:32 #45025
Last edit: 16 Mar 2022 01:32 by Terry Cockerell. Reason: Adding picture
- George van Nostrand
- Thank you received: 35
16 Mar 2022 00:38 #45024
by George van Nostrand
Replied by George van Nostrand on topic INTERIORDOOR HARDWARE
Steve: In your second picture , the LH one looks correct. PN G-3035.
Believe all eight escutcheons are the same
- A.S. KOLLER
15 Mar 2022 23:21 #45021
by A.S. KOLLER
INTERIORDOOR HARDWARE was created by A.S. KOLLER
I just got my 812 back from the trim shop and am ready to install the door hardware.
It seems that the hardware that I received with the car is a hodge podge of parts from different cars.
I have four escutcheons that are 1 3/4" wide and 5/8" high and four that are 2 1/8" wide and 3/8" high.
The profile on one of the wider escutcneons is also slightly different.
I would like to know which are the correct ones and if anyone has any extra, I would be interested.
I also need one door handle as one of mine is broken.
Hopefully you will be able so see what I am talking about in the attached pictures,
Steve
Steve
