- Thank you received: 35
Rocker shaft plugs
- George van Nostrand
25 Nov 2022 20:59 #46468
by George van Nostrand
Replied by George van Nostrand on topic Rocker shaft plugs
Thomas . A picture of the oiler plug.
- Emporator
25 Nov 2022 02:35 #46461
by Emporator
Replied by Emporator on topic Rocker shaft plugs
Thanks again for the response. I’m inclined to proceed with the oiler hole. Would you happen to have a pattern or the like for its placement?
25 Nov 2022 00:40 #46459
Yes, there are 3 plugs in the rocker shafts, 2 in the LH ( long ) shaft and 1 in the RH
(short) shaft- in front. The oiler hole in the LH plug was not a factory feature, but was suggested by someone to improve the life of the chain and sprockets, well worthwhile.
- Emporator
22 Nov 2022 09:07 #46438
by Emporator
Hello gents,
Thanks kindly for your responses. I’ve forwarded the information to my restoration guy who was most appreciative.
- Thank you received: 305
22 Nov 2022 08:40 - 22 Nov 2022 09:51 #46437
Last edit: 22 Nov 2022 09:51 by Terry Cockerell.
22 Nov 2022 01:27 #46436
Further to the reference of the two 1/8 " P plugs, the LH one is the timing chain lube PN PH6 ( with a hole) , RH has no hole.
I re drilled this hole at an angle - towards the timing chain so it would spray directly on the chain.
- E L
- Thank you received: 25
21 Nov 2022 22:32 #46435
by E L
Replied by E L on topic Rocker shaft plugs
Both long and short shafts have a plug at the timing chain end (rear) only
- Emporator
21 Nov 2022 10:58 #46426
by Emporator
Rocker shaft plugs was created by Emporator
Hi folks,
I have a question regarding rocker shafts. My restoration guy has sent me an email, the text of which is reproduced below from his email. Is anyone able to help with this please?
Trying to ascertain whether, or not, the rocker shafts have 1/8" NPT plugs, or any other item, fitted to the forward end, or is it tapped merely to facilitate removal with a screwed rod as mentioned in the Service Bulletin No.2, page3.
With the 2 short rocker shafts supplied with your engine parts, one has a plug each end, and the other nil. The long shaft that you obtained has one in the rear end only, and I believe this to be correct.
