I found a top mount fuel pump at Hershey for my Cord. The rocker arm spring and the lower diaphragm spring are the same length but one has a heavier gage wire. Is the heavier spring for the rocker arm or lower diaphragm? Should there be an upper diaphragm spring as in the exploded picture of a similar fuel pump? The Cord 810/812 parts list has only the rocker arm spring listed and no upper or lower diaphragm spring.
