Choke lever on dash
08 Jul 2005 17:58 #3328
by Josh Malks
Replied by Josh Malks on topic Choke lever on dash
Jack's description of the manual choke is quite correct.
I think, tho, that the reason for the choke lever on the dash and the dealer retrofit kit was to accomodate those who didn't trust the new-fangled device. As in "When I get too lazy to [choose one: use the choke/shift my own gears/etc.] I'll take myself to the old age home!"
- Jack Richard
08 Jul 2005 16:17 #3327
by Jack Richard
Jack Richard, D.D.S.This email address is being protected from spambots. You need JavaScript enabled to view it.
Replied by Jack Richard on topic Choke lever on dash
The Cord did not have a cable from the choke lever in the dash to the carb, but was a dealer-installed aftermarket addtition. The factory service bulletins (available from the ACD Museum) describe how it was installed and operates. It did not replace the electric choke control but supplemented its operation so you could choke the carb manually. It attached to the right (passenger) side of the choke rod. Many cars have had the electric choke and housing removed and the cable attached to the drivers side, but that was not how the factory did it. The problem was the electric element in the original tended to burn up and then no choke, no joke!
- E L
- Thank you received: 25
01 Jul 2005 01:54 #3304
by E L
Choke lever on dash was created by E L
As I understand all car came from the factory with auto chokes on the carb. Both supercharged and standard had electric chokes. If so , then how was the choke lever on the dash used and where did it connect?
