Cord 810 spring safety hangers
- Auburn/Cord Parts
23 Jul 2003 14:14 #520
by Auburn/Cord Parts
Replied by Auburn/Cord Parts on topic Spring Rods and Parts Available
Our front spring rods are like original (5/8" diameter) but are chrome vanadium steel. They are turned down for 9/16" threads. If they are installed properly and the spring travel is correct they'll work. If you do not have the rubber bumpers and the suspension arms move more than their designed arc, you'll bend and break any suspension built in time. We have all of the seats and rubber insulators.
Stan
Stan
- cbs
18 Jul 2003 19:19 #509
by cbs
Replied by cbs on topic Cord 810 spring safety hangers
<!-- s:shock: --><img src="{SMILIES_PATH}/icon_eek.gif" alt=":shock:" title="Shocked" /><!-- s:shock: -->
Part #D11264A "Rod Assy, ft. spring, HD 3/4" dia. chrome moly steel; Heat Treated; w/nut" $25.40 ea. from 1988 Cort Parts catalogue (J.K.Howell, Lombard Ill.) who also had (in 1999) the insulator, cover, seat, washer, locator. Safety loops also in catalogue, although I got mine from:
Auburn Cord Parts, Wellington Kansas; Item#5010 1 Pair Front Spring Safety Hangers (1/2" rod) $62.00/pr. (1999 catalogue)
Original Cord part rod assy. was 1/2 " dia. bar stock at location of failure, slightly larger at lower half.
17 Jul 2003 00:06 #499
by Tom_Parkinson
Replied by Tom_Parkinson on topic Cord 810 spring safety hangers
Ref: Safety Spring Retainers and Spring Bolts--
I have for decades cast a suspicious eye toward the two spring bolts that have been aging at least as fast as I have been. I vote (It's a landslide 1-0 election here) to replace them with modern equivalents or better. Here's the question--what spec should I try to meet for these two bolts? I see ranges of strength varying from chewing gum to Dilithium Crystals labeled as "aircraft grade." Anyone have a knowledgable strength number I should reach for? Note: originality is not an issue with my car.
As for the safety spring retainers, are they available, or does one make his own?
----Tom
----Tom
- Auburn/Cord Parts
16 Jul 2003 15:54 #496
No, this was a factory retrofit. At around serial number 1800 the factory started to install them.
Stan
Replied by Auburn/Cord Parts on topic Re: Cord 810 spring safety hangers
dpssma1 wrote: Did the early Cord 810 have spring safety hangers?
D.P. Smith
Stan
- Brad Waken
13 Jul 2003 16:24 #484
by Brad Waken
Replied by Brad Waken on topic Cord 810 spring safety hangers
Additionally, this item would also be looked at as a safety issue in judging. Safety adjustments are usually overlooked on driven cars (and yes we can tell) because most of us like to see these cars out on the road. Sad but true, it is extremely tough (but possible) to drive and show a 400 point car.
b
b
- Brad Waken
13 Jul 2003 16:19 #483
by Brad Waken
I would also suggest 5/8" steel suspension rods instead of the 1/2". I have broken two sets of suspension rods and the spring hangers (original) have "saved the pavement" both times.
b
b
- cbs
13 Jul 2003 13:58 #482
by cbs
Hey we're within a few dozen cars of each other (renumbered 36 now 1477) and there were no spring hangers until I installed after THE INCIDENT. If it's by mileage, be sure to retrofit before 65,000 miles; If it's by years, you're overdue. (The front end is known to have never been removed or modified back to '37 on this car).
Best of all, you don't have to remove the fenders to install the new bolts or drill/install the safety straps. But if you don't do it soon, you run the risk of either damaging the asphalt on your local road like I did, or worse causing body damage to the car and yourself!
Suggestion: Either install the spring hangers on your '36 and endure the comments at Auburn about whether you know they aren't original, or else install a roll cage with 5-point seat belts in anticipation of when one of your bolts snap. The roll bar would probably be a points deduction if you go for judging, but I'd like to know whether any judges have comments on whether hangers would be a deduction (I doubt it). Even if you don't drive it on the road, everyone at least drives them a little bit, don't they? .....and it's impossible to keep them slow once you get rolling.
Back to topic, new bolt, no hanger would be appropriate for all '36 Cords.
Thanks, Cort
Thanks, Cort
12 Jul 2003 15:09 #479
by Tom_Parkinson
Hi,
My 37 Westchester, which is a re-numbered left-over 36, has NO provision for spring retainers. No mounting holes, in fact no indications at all, that such a thing was ever considered on this car.
Sounds like a good idea though... :rolleyes:
---Tom
---Tom
- dpssma1
12 Jul 2003 01:11 #477
by dpssma1
Cord 810 spring safety hangers was created by dpssma1
D.P. Smith
D.P. Smith
