- Thank you received: 28
Trailing Arm Lubrication...?
- Pat Leahy
20 Aug 2003 12:08 #678
by Pat Leahy
Pat Leahy
Replied by Pat Leahy on topic Trailing arm inner bearing removal
I removed the bearing by using a short stock of cold rolled steel just macined slight smaller than the OD of the Torrington bearing. From the inside I used a porta-a-power to push the bearing out. Try to put lpenty of penetrating oil on it in advance. Good luck, they can be stubborn.
Pat Leahy
20 Aug 2003 00:39 #673
by Tom_Parkinson
Replied by Tom_Parkinson on topic Trailing Arm Lubrication...?
Thank you Stan!
Next question, how to get the inner needle bearing out without damaging it.....
( <!-- s:arrow: --><img src="{SMILIES_PATH}/icon_arrow.gif" alt=":arrow:" title="Arrow" /><!-- s:arrow: --> With luck the freshly-painted frame will be back on the body and The Hulk will be trailered to Auburn.)
- Auburn/Cord Parts
18 Aug 2003 21:47 #659
by Auburn/Cord Parts
Replied by Auburn/Cord Parts on topic Greasing Trailing Arms
You can modify the mounting blocks, if you have replacement bearings, to use grease zerks. Original bearings do not have a lubricant groove or any hole to admit grease from the outside.
The inner bearing cups can be modified to accept a zerk as well. Be sure the steering wishbone ends clear the zerks.
Stan
Stan
18 Aug 2003 04:05 #646
by Tom_Parkinson
Trailing Arm Lubrication...? was created by Tom_Parkinson
Hi,
Well, I actually got some work done on my car this weekend, including removing the trailing arms for priming and painting. In taking them off I observed <!-- s:shock: --><img src="{SMILIES_PATH}/icon_eek.gif" alt=":shock:" title="Shocked" /><!-- s:shock: --> that there is no provision for greasing the two big pivot bearings.
Is there a modification in use by members to allow the introduction of chassis grease into these two locations (short of dismantling the car...) ?
---Tom Parkinson
---Tom Parkinson
