- Thank you received: 25
812 crankshaft
- E L
30 Jun 2009 23:37 #13898
by E L
Replied by E L on topic 812 crankshaft
OOPS
I incorrectly stated the sizes of the crankshaft bolts. They should be 7/16 and 9/16. Hope it did not cause problems
28 Jun 2009 03:26 #13861
Replied by mikespeed35 on topic 812 crankshaft
Very interesting George, How do you keep the weld spatter off the journals? I presume the crank is balanced after the weight attaching screws have their heads welded.
- hsalmon
28 Jun 2009 02:43 #13858
by hsalmon
Replied by hsalmon on topic 812 crankshaft
E.L,
Thank you very much for your fast answer. I will do exactly as you said!
- E L
28 Jun 2009 01:28 #13857
by E L
Cranks were bolted and welded. The bolt tops are welded to the weight to keep them from un-screwing. These were special bolts that the head twisted off at a set torque. You will have to cut the weld and un-scew the bolts or run an end mill down the center to cut off the head. Use 3/8 and 7/16 allen cap screws to re- attach the weights. Re- weld the heads and the sides of the weight just as they were.
- hsalmon
27 Jun 2009 19:43 #13851
by hsalmon
812 crankshaft was created by hsalmon
Restoring my 1937 Phaeton S/C, I am now starting to work on the engine.
My crankshaft counter weights are welded to the shaft. By the way, a beautiful welding job. Did they come welded from the factory? or was this done by some repairshop later on?
I have to remove the counter weights to restore the crankshaft. Once this is done the right way to put the counter weights back is to screw them only? Or also to weld them again?
Herve
Herve
