Cross shifter arm 'play'
- Bill Hummel
Ric Simpson wrote: Hi! All the best, Ric.
Hey Ric!
Where were you this year? I did not see you in Auburn and you are hard to miss!
Bill H.
- oldbanger71
The only way you get out of this will be, that you offer them a drive with your ( repaired ) Cord to chauffeur them to the Laywers for divorce and have an other romantic brakedown, they will remember well and make up.
If not ....... you better run !!! <!-- s:lol: --><img src="{SMILIES_PATH}/icon_lol.gif" alt=":lol:" title="Laughing" /><!-- s:lol: -->
812 310 121 S
Scott Fergusson wrote:
And by the way, I'm chauffeuring the car in a wedding this weekend... What could go wrong?
On the Cord? Or in the marriage? <!-- s:lol: --><img src="{SMILIES_PATH}/icon_lol.gif" alt=":lol:" title="Laughing" /><!-- s:lol: -->
- Scott Fergusson
As Ric wrote - the arm and dogbone are held in place with a taper pin or 'pinch' bolt that once I stopped pounding on the wrong side came out easily.
Getting the dogbone off the end of the shaft was a real ordeal though. Since I had a new shaft, we drilled through the shaft close to the dogbone to break it off.
Bushings came out ok. The vacuum end of the shaft had an small ring and original leather seal as well. I bought a new seal.
I'll be putting the pieces back together.
Scott Fergusson
1937 Custom Beverly
Rich Maroon with Burgundy
Back on the road, June 2009
Received 2nd in Class, Auburn Reunion September 2009!
If you have scanned those plans I'd be grateful if you could email them to me or post them in the forum. The Old Lady is not ready for dealing with this particular set of problems yet, but the time will come.
Thank you,
As promised, I took a look at the cross shifter in The Old Lady. My car is fitted with an Allen cap screw that is secured with an anti-backout wire! Who knows when that was installed?!?!?
- Ric Simpson
the shift arm is located by a woodruff key, and opposite a taper plug that is driven in to hold the arm tight to the shaft. Most of the cars I had had been worked on by previous mechanics and a favourite way to secure the shifter arm was welding, brazing, maybe airplane glue. Whatever it didn't work and you are left with the problem of removing the arm. In your case it sounds like you could drill, tap and pull the taper plug out so the shifter arm will move off the woodruff key. I don't think you can get on the other side of the plug to drive it out???. You have the same problem with the "dog bone" piece that moves the shift rails. It is inside the cross-shift housing. Same style of fixing, (woodruff key and taper plug). As you are working, I suggest the least important piece is the cross shaft itself. You will probably be replacing it with a new one as I believe they are available, maybe in stainless. I'm not sure the shifting arm and "dogbone" are. If you break either of them, I may have some in my parts bin. New bushings are important (bronze or brass?) mine were machined to hold 0-rings to further seal the vacuum. I have a blueprint of the machining for the set-up
made by Wat Adams in the 60s if it would help. Ric.
Ric Simpson,
2001 Niagara Parkway,
Fort Erie, Ontario,
Canada. L2A 5M4
- oldbanger71
812 310 121 S
- E L
- Thank you received: 25
Since my car shifting hardware is, to the best of my knowledge, original, I'll look at my shifter tomorrow and see what I can tell from it. Hold off on the hammer until you KNOW what's up with it.
- Scott Fergusson
The arm is on the shaft and has play, but if there ever was a screw squeezing the arm to the shaft mine doesn't have it - it looks like two rounded nubs of metal and the paint looks solid, like the casting never had a cut in it. There doesn't seem to be a way to loosen the arm at all. Do I just pound it down past the woodruff key?
Does anyone have any advice/been there, done that help?
Scott Fergusson
1937 Custom Beverly
- Ric Simpson
Ric Simpson,
Fort Erie, Ontario,
Canada. L2A 5M4
- Scott Fergusson
Scott Fergusson
1937 Custom Beverly
- Ric Simpson
Ric Simpson,
Fort Erie, Ontario,
Canada. L2A 5M4
- Scott Fergusson
After I pulled the transmission cover off, I noticed that the cross shifter arm moves quite a bit before it engages the shaft - maybe 1.5" arc at the top of the arm. This seems to be acceptable for 2nd and 3rd, but the reach combined with the play makes it tough to get into fourth and difficult to get out of fourth.
My guess is that the arm is wearing out -
Any guidance is definitely appreciated.
Scott
Scott Fergusson
1937 Custom Beverly
