Ideas for engine swap for Westchester
- Scott Fergusson
Scott Fergusson
1937 Custom Beverly
Rich Maroon with Burgundy
Back on the road, June 2009
Received 2nd in Class, Auburn Reunion September 2009!
- Scott Fergusson
Scott Fergusson
1937 Custom Beverly
- Bill Hummel
Fortunately Scott took that option away from me.
- alsancle
- Thank you received: 17
A.J.
- Bill Hummel
There is no Cord frame in front other than the stubs that the previous owner used to weld the frame to.
Of course, I prefer correct cars, but I am not the one to ressurect this one. I don't think I am doing any more permanent damage, that has already been done.
I think cleaning up the engine compartment and putting in a correct interior will help this car immensely.
I always keep my eyes open for correct cars. That's what nice about this Club! We're always surrounded by an incredible collection of cars.
- petlodge
- Bill Hummel
Rear drive using a GM Turbo Hydra-Matic 400 transmission. Ford 9" 12-bolt differential. Drum brakes.
Replacement gas tank, Holds about 12 gallons.
It has a tube support running from side to side to strengthen the body.
Has an Olds 455 engine sitting in a Cadillac(?) sub frame that was welded onto my Cabriolet body.
Steering column is from the 70's with a Grant banjo steering wheel.
Interior is early "Denny's Diner" with a single bench seat covered in black vinyl.
The car looks nice but definately has a long way to go to either become correct or become a top notch retro rod.
After 7 years of thinking about it, and getting ideas from other Club members, I have finally come to the conclusion that this particular Cabriolet is too far gone to go back to being correct.
I am going to try to make this one a nice retro-rod. There won't be anything visible to tip off the casual observer that this Cord is anything but original.
It is absolutely futile to fool this crowd, but 99% of the people out there won't know there is anything modern on it.
Here is a camera photo of the tubular cross-beam I mentioned earlier. The drive-train and rear axle have been removed. I am cutting down the rear axle so the rear wheels have a 61" centerline. I may change the gear ratio to one that will give better highway performance. New leaf springs are being ordered. New disc brakes are being ordered. A new stainless steel gas tank and sender are on the way.
- petlodge
- Bill Hummel
Th 455 has lots of power but it needs to be put back into a muscle car.
- oldbanger71
812 310 121 S
- Bill Hummel
Currently I have an Olds 455 in it. It is so big that I cannot install my Cord steering column and steering wheel.
I am getting ready to yank the engine and install a crate Chevy 350 which is a lot smaller.
- Scott Fergusson
Where I'm at is the last 10-15% of making it *really* like it was. The reunion this year showed me the extent that folks will go to make it correct - but that's a whole different thread.
Scott Fergusson
1937 Custom Beverly
- Pat Leahy
- Thank you received: 28
Pat Leahy
- Steve Derus
- alsancle
In the 1950s there were many engine swaps done. Caddy, Olds, even some big straight eights were put in (minus the radiators) for drag racing.
- petlodge
