Exterior door handle droop
- Mike Markin
03 Nov 2009 23:46 #14846
by Mike Markin
Replied by Mike Markin on topic Exterior door handle droop
Well, I had a pretty strong idea that this topic had been discussed before! Looks like it is unanimous. I'll let you know how it turns out. Thanks all for helping the helpless.
- elliotta
03 Nov 2009 13:04 #14841
by elliotta
Proprietor of the Cord Supercharger Parts Database
Replied by elliotta on topic handle droop - look at the thread from November 14, 2008
Check out my posting on this topic last November 14 and the resulting responses from Club members. The "handle droop" was apparently a design flaw right from the start. Even if you could start with all new handles and new lock/latch mechanisms you'd have all four handles angled down. The only satisfactory solution is the heat and twist process. And it's not that difficult to do with a gas torch, a vise, and a Crescent wrench.
- Mike Markin
30 Oct 2009 20:36 #14809
by Mike Markin
Guess I may not have been clear on the droop. The droop occurs in that the internal mechanism that holds the door handle shaft causes a slight downward angle but it is not loose. The handles are always angled (drooped) downward a bit but are firm in their place.
- Bill Hummel
30 Oct 2009 19:46 #14805
by Bill Hummel
Replied by Bill Hummel on topic Drooping
How about some sort of spring to hold them up? That's what Chevrolet did with its drooping door handles.
My wife has a 41 chevrolet pickup that has door handles that droop. I ordered spring assemblies to hold them up. I have not installed them yet, but when I do, I will see if they will also work on a Cord.
- alsancle
- Thank you received: 17
30 Oct 2009 13:13 #14801
by alsancle
Replied by alsancle on topic Exterior door handle droop
The heat and twist method has been used for 60 years so I think it qualifies as period correct .
30 Oct 2009 12:06 #14800
by
Replied by on topic door latch
Like I said if the handle only droops when the door is closed, that means the actual door catch is not being totally released when the door is closed. That is the part you need to look at.
My 2 cents Ken Clark
- oldbanger71
30 Oct 2009 11:29 #14797
by oldbanger71
812 310 121 S
Replied by oldbanger71 on topic Exterior door handle droop
Maybe you can try with shimming the wedge and put the door it's self in ligne agin
812 310 121 S
- Mike Markin
30 Oct 2009 01:33 #14795
by Mike Markin
Ken,
I had already pull the latches out, cleaned and re- greased them. They look good. The door handles droop when the doors are closed. There are several screws that hold the latches in place and I have played with them a bit as it looks like that may be the key but I haven't had much luck.
29 Oct 2009 12:29 #14786
by
Replied by on topic out side handle
Something is either worn or your latch is not able extend all the way out when the is closed. Or does it droop even when the door is not closed? If that is so something is definitely worn. In that case you will need to take out the latch assembly and figure out what is worn and then how to fix and reassemble.
My 2 cents
Ken Clark
My 2 cents
Ken Clark
- Mike Markin
29 Oct 2009 00:18 #14779
by Mike Markin
Lee,
I have heard about heating and twisting but the originals weren't done that way so I am curious how to do adjust the handles the way Cord did it.
- Lee Titus
23 Oct 2009 16:50 #14720
by Lee Titus
Replied by Lee Titus on topic handle droop
Heat and twist the square shaft .......good luck Lee Titus
- Mike Markin
23 Oct 2009 15:14 #14719
by Mike Markin
Exterior door handle droop was created by Mike Markin
I am installing replacement exterior door handles. They droop and are not positioned horizontially. How are they to be adjusted? Thanks
