Head light cables rotation
- Mike Markin
07 Mar 2010 13:49 #16068
by Mike Markin
Replied by Mike Markin on topic Head light cables rotation
Thanks, EL I have put them into a tank of penetrating oil to see if that will make a difference before going further. I'll keep you posted.
- E L
- Thank you received: 25
07 Mar 2010 04:11 #16066
by E L
Replied by E L on topic Head light cables rotation
If only the outside wire is the problem causing rotation , I will be able to fix the problem if you want to send them to me. Cost is 150.00 and takes about 3 hours You must have a lathe and a fixture to load the cable and wind at the same time. Also the wire has to be wound tight.
- Mike Markin
06 Mar 2010 13:41 #16060
by Mike Markin
I'll take a close look at mine today. I sounds as though there must be a problem with that outer cable. I, too would be interested in how E L repaired the cables. Phillip, the cables came with the car when I purchased it. It came in boxes. It has been a great puzzle to put this Cord together.
- oldbanger71
06 Mar 2010 01:30 #16059
by oldbanger71
812 310 121 S
Replied by oldbanger71 on topic Head light cables rotation
Hi EL, how do you replace the two most outer spiral wirelayers ( one winded to the left, the other winded to the right )?
Actually there is the turning soul( cable ) then the larger spiral and on top of that the two layers of thin wires .
In my case, on one of my cables, the two layers of spiralwires are rusted through and broke off in the middle und have unwinded so i had to cut them off in the knowledge of needing to replace, i was looking for a specialist to do it but haven't found one yet, is there a way to do it my self ? If so, would you mind giving me a detaild advise, please ?
Cordially Philipp
Cordially Philipp
812 310 121 S
- E L
06 Mar 2010 01:07 #16058
by E L
Hello, If the spiral wire is broken on the outside they will not turn easy. I have repaired several of these with new wire and they work in either direction. The outside wire is what keeps the cable from unwinding and therefore jamming the ends
- oldbanger71
06 Mar 2010 00:06 #16057
by oldbanger71
812 310 121 S
if they are out they need to turn in both directions without hesitation, are the couplings on one sie sligthley more coroded or used on each headlighcable ?
From who did you buy them ?
Cordially Philipp
Cordially Philipp
812 310 121 S
- Mike Markin
05 Mar 2010 23:45 #16056
by Mike Markin
I sort of suspected they need to travel both diractions but wan't sure if there was a catch mechanism that would trip them into turning backwards. I am assembling the car so they are out and have been that way since I bought them. I can't tell if they both turn the same directions as it depends which end is used. Both ends look alike to me. I plan on keeping them but need to figure out what is stopping them both from turning only in 1 direction.
- oldbanger71
05 Mar 2010 23:20 #16055
by oldbanger71
812 310 121 S
Hi Mike, at the moment i deal a lot with the topic of healight mechanisme. Actually the cables have to turn left and right with no difference if seperated from the headlight assembley and the handcrank assembley. Possably the cablesoul starts to unwind inside, hench you can turn them only in one direction. Do both turn in the same direction ?
Are they fitted to the car ?
In the handlegear just behind the dashfacia there is a spring mounted to keep the windingcables in position rotation wise, but with a light push schould overcome this. Would the cables be for sale ? I might be interested to buy.
In either case please send me pic's to my direct e-mail-address :
Cordially Philipp
Cordially Philipp
812 310 121 S
- Mike Markin
05 Mar 2010 22:00 #16054
by Mike Markin
Head light cables rotation was created by Mike Markin
I have 2 cables that turn very easily in one direction but not back again. They do not seem bound up inside. Nevertheless, I presume this is incorrect . Can someone enlighten me about this? Thanks.
