Cleaning Gas Tank
- AceCollins
07 Oct 2010 16:22 #18138
by AceCollins
1934 Auburn 652Y Four-Door Sedan
1936 Cord 810 Westchester
Replied by AceCollins on topic Cleaning Gas Tank
Thanks. I will give this a try. I really appreciate the links.
- oldbanger71
07 Oct 2010 16:19 #18137
by oldbanger71
812 310 121 S
Replied by oldbanger71 on topic Cleaning Gas Tank
Do not get it Sandblasted as heat with little left petrol might cause a explosion, but will for sure leave enough sand in the tank to clog up the fuel lines, no matter how well you clean out the tank,sand is forced into the steel by blasting. With vibration sand will come out of that steel !
This at first.
You can get it chemically rust and paint striped and well neutralized, or sand the outside, fill some wood-screws in the tank with hot water degeasing soap and slosh arround well for a while ( concrete mixer works well or old waschingmachine ) make sure that you get all dirt and screws out again, then use a hot-water-pressure-gun to clean inside and out.
Next stage is to use a good tank-sealer like LJF PR 1005 L.
I have done several tanks in the past 12 years and had no trouble at all.
good luck.heres the link
aerosparesltd.com/files/ljf/pr_1005_l.pdf
www.aircraftspruce.com/catalog/appages/bunan.php
This at first.
812 310 121 S
- AceCollins
07 Oct 2010 04:37 #18135
by AceCollins
Sadly no dealers within 500 miles of me. So still looking for answers.
07 Oct 2010 04:35 #18134
by Tom Georgeson
Replied by Tom Georgeson on topic Cleaning a gas tank
My tank was dirty and had a big dent in one corner. I took it to a place in Stockton, CA and they did a nice job. Took out the dent and cleaned and sealed it. This was four or so years ago. As I remember it cost a little over $200. The process is called Renu and they are located all over the country. The number to call to locate a shop near you is: 800-997-3688
- AceCollins
07 Oct 2010 01:28 #18133
by AceCollins
Cleaning Gas Tank was created by AceCollins
My Westchester's gas tank has rust particles that are about the same size as beach sand. I can't drive it very far because it plugs up the fuel pump and filter. What do I need to do? Drain it and then what? Is there a way to clean it or do I need to put in a new one? And if a new one is the way to go, who makes something that will fit in the 810?
