Installing Headlight Buckets
- Mike Markin
22 Nov 2010 01:49 #18502
by Mike Markin
Replied by Mike Markin on topic Installing Headlight Buckets
It binds along the top lip on the right on the same side as the cable. I have a fractional gap on the sides.
- oldbanger71
22 Nov 2010 00:49 #18501
by oldbanger71
812 310 121 S
Replied by oldbanger71 on topic Installing Headlight Buckets
Where exactly is the lid fouling the fender ? is it the same spot left and right ?
812 310 121 S
- Mike Markin
22 Nov 2010 00:23 #18500
by Mike Markin
They were on the car before I bought it. However, they had been removed and were in a box. When I bought the car it was partially restored so the fenders may have been reworked as I did not need to do any work on them.
- oldbanger71
21 Nov 2010 22:13 #18498
by oldbanger71
812 310 121 S
Where they ever installed in the fenders before ? was the Fender reworked in any way ?
812 310 121 S
- Mike Markin
21 Nov 2010 21:59 #18495
by Mike Markin
Yes, I have the correct ones. Thanks
- oldbanger71
21 Nov 2010 18:52 #18493
by oldbanger71
812 310 121 S
Mike, No, the screws i talk about are those holding the healightframe to the lid, marked with red arrows on the pic; each side of each headlight.
812 310 121 S
- Mike Markin
21 Nov 2010 16:44 #18490
by Mike Markin
Philipp,
Are you referring to the mounting holes that hold the canister to the fender?
- oldbanger71
21 Nov 2010 11:52 #18487
by oldbanger71
812 310 121 S
mak sure you have the large very flat slotted screws fitted on both sides of the housing since hexnuts will not clear the fender.
812 310 121 S
21 Nov 2010 00:06 #18480
by Tom Georgeson
Replied by Tom Georgeson on topic headlight buckets
Only thing I could add, other than good luck, was to be sure you don't put them in the wrong fender. My body man put them in the wrong fenders. The cable connection goes on the inside of the fender, he put them in the outside and of course the cables couldn't be connected.
- Mike Markin
20 Nov 2010 23:52 #18479
by Mike Markin
Installing Headlight Buckets was created by Mike Markin
Is there a trick to installing the Cord head light buckets?
I have reassembled the lights and need to install the buckets in the fender. I have tinkered with the adjustment screws on the back and the inside rotator screws that hold the lid. I am having trouble with the lid clearing the fender opening when opening and closing. The lights have not been put in the housing yet. Any help would be appreciated. Thanks
