head light conversion
- Brad Waken
- John Alkire
John Alkire
Houston, TX
ACD Life Member
- Mike Dube
Josh Malks wrote: Yeah, and there would be an additional problem with Cords -- you would have to crank open that headlight every time you wanted to signal a turn.
I don't think that would make much difference in my part of the world, no one here (including the cops) uses turn signals anyway.
8-100A
Like some other cars of the era, the parking lights in the Cord are incorporated into the headlight reflector. (Essentially, it's the equivalent of a flashlight bulb stuck into a hole in the reflector.) Moving the headlight switch to the first detent turns on the parking lights, which makes the headlight lens glow dimly.
- John Alkire
John Alkire
Houston, TX
ACD Life Member
- oldbanger71
In case you cut the reflector chances are grate that you loose a lot light output since positioning the bulb in the reflector is difficult. As little as 0.039 zoll to one side will get you out of scale and possibly will render you with a useless headlight adjustment system.
Never the less if you realy need to keep your lenses cut away the WHOLE REFLECTOR and grind it down right to the edge of the glass to have a nice clean surface ( carefully with a real glasscuttingtool and no pressure since your reflector is most likley also glass. try first with a glassbottle to see if you have the skill and tool. I do not recommend to do it when the reflector is of glass. I take no responsability in case you damage either your headlight or injure your self or others with this task, now or later.) and replace it with a same size reflector gluing it with two composite glue. This will give you at least a chance to have a centered bulb.
Make sure that you use a steel or brass reflector no plastic ( look a Hotrodshops ) and by then i recommend to use 6 v or 12 v 45/55 w halogene-bulbs with Bay 15 d socket so the reflector must be reddy to accept Bay 15 d bulbs these are most common and radley available. Since i import Halogenbulbs to europe i can tell you more about it. but these bulbs are also available in the US. My e-mail is <a href="mailto:[email protected]][email protected][/url] <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
812 310 121 S
- Red Fred
I'm wondering if anyone has concocted a method of cutting this bulb area out, and substituting it with a replaceable unit? I sure would like to retain these cool lenses, even if they aren't correct.
TIA, RF.
Life Member
