Tranny Cover Removal
- Mike Markin
12 Aug 2011 16:58 #20716
by Mike Markin
Replied by Mike Markin on topic Tranny Cover Removal
Thanks, Pat. I appreciate it.
- Pat Leahy
- Thank you received: 28
12 Aug 2011 14:52 #20715
by Pat Leahy
Pat Leahy
Replied by Pat Leahy on topic Tranny cover
Yes, first remove the (2) bolts holding the bumper assemble to the frame/body. Then remove the 2 -1/4" bolt behind the fence (grill) holding the cover to the fenders. Last (if present), remove the 2 bolts at the bottom of transmission cover to the fender frame. Carefully slide straight out.
Pat Leahy
- Mike Markin
12 Aug 2011 14:14 #20714
by Mike Markin
Tranny Cover Removal was created by Mike Markin
I am getting to fianl assembly of my Cord 812 and now find that in order to remove the tranny cover, I must first remove the front bumper. Is this correct? If not, any ideas? Thanks
