Looking for a reproduction dash for a 1936 Cord without any holes cut out
- ransome
18 Jul 2018 08:48 #34979
by ransome
Replied by ransome on topic Looking for a reproduction dash for a 1936 Cord without any holes cut out
I have a metal guy that says he can duplicate that dash ,I guess I will put him to the test
- ransome
05 Jul 2018 18:18 #34911
by ransome
Hi
Unfortunately the only ones he has are already cut with the holes , I needed one with no holes cut out.
Thanks Gregg
Thanks Gregg
05 Jul 2018 14:00 #34907
Replied by 1748 S on topic Looking for a reproduction dash for a 1936 Cord without any holes cut out
No eBay APP ID and/or Cert ID defined in Kunena configurationThis is the ebay seller and is also an ACD member. Hope it helps you out in your quest.
- ransome
04 Jul 2018 18:10 #34902
by ransome
Hi
I don't have the newsletter , would you have that members contact info.
Thanks Gregg
Thanks Gregg
04 Jul 2018 16:05 #34901
A seller on ebay sells both the sedan and the convertible dash. Also a member that advertises in the back of the news letter also sells one. I don't recall which one claims to have reverse engineered the engine turned panels. Might also talk with Doug Prey at the ACD factory in Broken Arrow Ok.
- ransome
04 Jul 2018 10:12 - 04 Jul 2018 10:14 #34899
by ransome
Looking for a reproduction dash for a 1936 Cord without any holes cut out was created by ransome
Looking for a reproduction dash for a 1936 Cord without any holes cut out , the gauges have been changed. I am wanting a blank engine turned dash so that I can cut different holes. I thought there was one or more members making these
Thanks Gregg
Thanks Gregg
Last edit: 04 Jul 2018 10:14 by ransome.
