- Thank you received: 16
Gear Selector Switch Wiring
- alsancle
You need tiny but strong pull string. And you need to tape in a way that doesn't bulk up the package.
Hopefully Friday we solder.
- Thank you received: 305
You have a very nice looking phaeton.
- alsancle
Because I eliminated the plug I have the one piece harness. I'm not sure I could pull the entire thing down from the top?
I do agree it would be much nicer to do the solder work on a bench. I've been evaluating the notion of soldering very small portions of wire to the switch on the bench and then using solder seals to do the connections. The solder seals just get heated with a heat gun. The issue is clearance as the seals are slightly larger in diameter than the wire.
- alsancle
- alsancle
- Thank you received: 135
- alsancle
- Thank you received: 219
From photos I remember you posting previously your switch is a "new" design. Also the ring with the loop on it is a newer design. As far as I know all the original rings were were just that...a ring.
- George van Nostrand
- Thank you received: 35
It may have been an updated design with the new plastic body switch.
Sorry I don't have a picture of it.
- alsancle
Still waiting for RI wiring to ship the new full length harness.
- alsancle
Examining my switch (see pictures) I see no cracks or breaks just horrible solder work. There is grease on the end contacts and I'm not sure if they was causing issues. I have a new replacement switch but may reuse this one. Thoughts?
- alsancle
Rileypu29 wrote: I just purchased two water pump rebuild kits from Cathy Portz who is indeed still selling Henry's parts. There is a website for ordering. Cathy is great to work with and shipped the parts very quickly. I highly recommend buying parts from her.
Bill Kastanis
Thanks for the information. I'm located about 3 hours south of this. I really want to walk thru the Henry shop just to see what he was doing and look at the tooling. Maybe purchase something I "can't do without"... Tell the wife I just need one more part....
- Rileypu29
Bill Kastanis
Bill Kastanis
- alsancle
- alsancle
I told my dad we are taking the steering tube out and he was disagreeing since he didn't have to do it last time, and I pointed out that last time he didn't replace the harness.
Originally there was a cardboard "washer" the wires ran thru that was located at the base of the shift arm (at the steering column). Your best bet is to pull in two or three wires at a time. I always use a string to pull in the wires and ALWAYS have a spare pull string in the column.
Make sure you have the inside grommet fitted to the column tube as shown in the attached picture.
- alsancle
- alsancle
You must first slide the ten wires up through the steering column cover tube and solder the new switch in position. Run your tests with the column out of the car. Eventually when installing the cover tube complete with wiring make sure the inside grommet is in position. Pass the wiring through the firewall then slide the cover tube down the steering column. To refit the engine side grommet you will have to cut it radially as it won't fit over the wires coming out at the bottom of the cover tube. Place the grommet in position and superglue the cut joint. This procedure worked for me.
- alsancle
Bad idea?
- alsancle
The trade-offs I see are:
1. A single harness eliminates any issues with the plug.
2. A single harness eliminates me trying to solder the connections on to the plug
3. A single harness means you can't pull just the selection harness out to work on the switch.
4. A single harness means more work with installing the front 1/2 of the harness.
Final question, if I go with just the selection harness, is anyone making the plug or half the plug?
- alsancle
phpstack-1081784-3880776.cloudwaysapps.c...-if-i-have-a-problem
- rhauser
Robert l Hauser
If the end of the snap ring is not near the notch try and a use the screwdriver to move it around so it is near the notch.
This is one job I would rather be lucky then good. I have had this job take me as long as 4 hours to get the ring out. I've done it enough lately I can get it out in less then 5 mins.
If you are having problems call me
gARY pARSONS
- alsancle
- alsancle
AJ - the housing has a keyway cut in it and the switch has a square on it so it will only go in one way.
The original snap ring was just a circular piece. This makes it hard to get out. There are updated ones out there that have a ring on the one end that makes it easy to grab and remove the snap ring.
My next article for the Newsletter will be on this subject. Will also include testing the switch to make sure it will work in the car.
- alsancle
I will say that things are pretty tight. My question is probably simple, is there a snap ring holding the switch body inside the shifter housing? And can the body only go in one way?
thanks,
A.J.
The job could be done with the steering column tube cover in position but it would be more tedious. Having it all out of the car makes it a lot easier to work on as you can rotate the tube cover when soldering the various connections around the switch.
- alsancle
A.J.
Laying the cables out correctly is the key to success. The cables have to be slid into the steering column cover tube and pulled through from the bottom up to the switch . I had the cover tube out of the car with the cabin side firewall grommet in position. After carefully removing the old cables and soldering the new ones in position the switch was fitted to the cover tube. Eventually the new loom with a dummy 10 pin plug was fed through the firewall and the cover tube assembly slid down over the steering column and fixed in place. As you cannot slide the firewall side grommet over the cover tube with the cables in place, I simply made a cut through the grommet, positioned it and super glued the joint.
The gear selector switch has some contacts that are a tight fit in the plastic housing. In some reference material it said an ice pick can be used to push the contacts out. I figured pushing a point into soft material may make things worse. I cut the wires off flush with the plastic housing and used a small round flat ended punch to push them out. This worked well.
One day in the not too distant future I hope to be able to change gears again, when the restoration is finished.
One final note, I painted the insides of the switch gate black as it didn't look right in raw metal colours.
- alsancle
- STEVEN.KUIPER
- Thank you received: 17
essentially a rubber-like black tube(colors are available) that you slide back one of the wires before you soldier them. after soldiering is done slide it over the joint & heat lightly . then it shrinks down to size.
