L29 tire pressure?
  • mikespeed35
21 May 2022 04:03 #45449 by mikespeed35
Replied by mikespeed35 on topic L29 tire pressure?
Nothing other than the car weighs 4500 lbs. Can't give you a scientific answer, just not comfortable with it.
  • Joel
20 May 2022 04:30 #45445 by Joel
Replied by Joel on topic L29 tire pressure?
Thanks Mike. I've been running about 30 PSI. But I don't know if that is ideal. Maybe I'll pump them up a little bit and see how I like it. What is your concern about going lower than 35 psi?
Joel Nystrom
  • mikespeed35
17 May 2022 03:42 #45425 by mikespeed35
I use 35 Joel, but the tires will wear out on the center. I do not feel comfortable using any less though. I use 40 in my Marmon 16 with the same size tires but heavier car.
The following user(s) said Thank You: Jonathan Richards, Joel
  • Joel
13 May 2022 21:43 #45403 by Joel
L29 tire pressure? was created by Joel
Hi, what is the recommended tire pressure for an L29 cabriolet? Thanks, Joel
Joel Nystrom
