- Thank you received: 219
Capillary temperature gauge repair
22 Jul 2020 23:59 #40589
Replied by JIM.OBRIEN on topic Capillary temperature gauge repair
Mr. Martin has all the info on the length of the tubes. Just tell him the vehicle info.
22 Jul 2020 18:13 #40583
Replied by johnmereness on topic Capillary temperature gauge repair
If 34, 35, or 36 (and possibly earlier such as V-12 or ...), then this is a good telephone call to Frank Cek question.
- Thank you received: 19
20 Jul 2020 13:43 #40560
by balinwire
Replied by balinwire on topic Capillary temperature gauge repair
Sounds like I will send it in, I found Mr Martins # online, what is the length of the gauge to bulb copper line when ordered, 24"- 36"?
20 Jul 2020 01:38 #40555
I have used Roy many times over the years. THe work has always been first class and he stands behind his work. The work has always been done in s reasonable time.
19 Jul 2020 19:37 - 19 Jul 2020 19:39 #40551
Replied by mikespeed35 on topic Capillary temperature gauge repair
I tried this method from SK and was successful in getting a working gauge. The down side was the readings were not consistent. this was with a ether filled bulb. I don't know if some ether escaped in the process or what. Then sent the gauge to John Wolf and he fixed it. He can be found on line.
Last edit: 19 Jul 2020 19:39 by mikespeed35.
The following user(s) said Thank You: 1748 S, RubyDS
18 Jul 2020 22:01 - 18 Jul 2020 22:04 #40546
by balinwire
Capillary temperature gauge repair was created by balinwire
I have had no luck finding a working gauge. this one's bulb is broken off . I understand this is not uncommon for sensor bulb to twist off as they rust in manifold and are difficult to remove. I have the triangle dash gauge but the line is cut maybe to close. I am reading you can take another donor gauge sender and freeze it in a milk carton of water to chill the fluid and then cut off the donor head and solder the small copper line together with a sleeve shaped to the the old line diameter and soldered. When the ice thaws the fluid fills the tube giving a reading on the repaired gauge. Seems simple enough, has anyone tried this? I am not sure my donor has red fluid or mercury. Only trying this out of desperation since I cant find a working gauge set, any ideas? Does this seem like a fools errand?
I have this contact has anybody used his services, The Temperature Gauge Guy
Roy Martin
172 Laurel Hill Drive
So. Burlington VT 05403
802-862-6374
Roy Martin
802-862-6374
Last edit: 18 Jul 2020 22:04 by balinwire.
