31 Auburn Water Jacket Side Cover Seal
01 Oct 2006 04:26 #5521
Replied by mikespeed35 on topic 31 Auburn Water Jacket Side Cover Seal
I use locktite 242 with primer on the screws and locktite 515 with primer as a gasket sealer. 515 will seal deviations in the gasket surface up to .050 if you use the primer. If you use SS screws you need to for sure use the primer.
CORDially
CORDially
- Ken Dorn
17 Sep 2006 17:21 #5443
by Ken Dorn
31 Auburn Water Jacket Side Cover Seal was created by Ken Dorn
Having trouble with leaks around my water jacket side cover. Does anyone have any recommendations as to what is the best type of gasket seal to use or how to remedy this? I have torqued the screws and used permatex high temperature thread sealant on the screw holes with the copper/fiber core washers and permatex aviation "form-a-gasket" on the gasket.
